250-500cc engine swap?
Discussion in '2 Stroke' started by 02wrhusky, Mar 12, 2013.
  1. 02wrhusky Husqvarna
    2002 wr 250
    honda cr 250
    I was just thinking could I swap my 2002 wr 250 2 stroke for a 4 stroke engine ? are the frames even the same just wondering
  2. msmith345 Husqvarna
    Shawnee, KS
    '12 WR250, '92 360, '80 390
    '72 Yamaha R5, '17 SV650
    I highly doubt the mounts would line up, let alone the chain line.
    What are you trying to accomplish exactly? I'm thinking if you want a fourstroke, you'd be better off selling and buying one. If you want something more tractable, I'd say a flywheel weight would be a good place to start. Followed by a pipe tuned for low end like an FMF gnarly with a long silencer.
  3. old3 Husqvarna
    NJ
    I've had a bunch of Husky 4t 450s, no way the engines will fit.
  4. 02wrhusky Husqvarna
    2002 wr 250
    honda cr 250
    I'm not going to do it i was just thinking has it ever been done before im fine with my 2 stroke
  5. old3 Husqvarna
    NJ
    The other way is popular with later model KTMs, new frames and running gear, older 2t or even 4t engines. The 4t requires a bigger cradle to fit so getting a 2t in there isn't much of a problem.
