Eric's stamped on cylinder???
Discussion in 'Vintage/Left Kickers' started by frog, Sep 19, 2009.
  1. frog Husqvarna
    MN
    I puchased a 1983 Husky 250XC/WR project and the cyliner is stamped on both sides Erics. I was thinging maybe Erics the Husky dealer in Califoria maybe did this back in the day? Or maybe this was a former factory bike? Thanks
  2. Up-tite Husqvarna
    Usually means that the porting work was done there. The person doing the porting that was the signature. Later George
  3. frog Husqvarna
    MN
    I guess that would make sense since it had some of your items on the bike. It's a strange bike-it has frame #'s of a 1983 250XC,but doesn't have the rear frame loop like a 250CR.Also I'm pretty sure it has a WR swing-arm because of the low seat height? Any idea's George?
  4. Michel Dufayard Husqvarna
    France
    Yes it is a WR swingarm ( brakes fixed to swingarm).
    On CR or XC, the brakes are fixed to the frame.
  5. Up-tite Husqvarna
    From the pic it has the CR floating rear brake. As far as not having a rear frame loop when the got looped out and bent just cut them off. Check for a skid bar under the motor cradle thoes were cut off also so a flat skid plate could be used. Later George
