125-200cc Exaust Leak - Affecting Jetting
Discussion in '2 Stroke' started by Tentontimmy, Apr 23, 2016.
  1. Tentontimmy Husqvarna
    Caribbean
    2012 WR125
    Suzuki GSX-R1000
    Hey everyone
    My bike's developed a leak where the exhaust meets the motor, and there's spooge leaking all over.
    Question: can such a leak cause the motor to run rich?
    The bike seems to be running richer all of a sudden and it coincided with the leak so I'm trying to figure out if they are related?
  2. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    when the exhaust is leaking the total amount of air pushed through the motor would probably less at the range where the pipe is tuned for and that's probably also the rev range where you like to ride the motor in
    if less air comes in the motor the percentage of fuel in the mix will increase and would result in running richer
    Robert-Jan
    Tentontimmy likes this.
  3. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    Get some new o-rings for the header. Have you looked at the plug, changed mixture, changed pre mix oil? Vent lines to carb not plugged are they?
    Do all that stuff and see if it goes away.
  4. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Yeah, pull the pipe and see wtf is going on. While the pipe is off shine a light in there and have a look at your piston and rings.
    :cheers:
  5. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    An clean all the soooge off then high temp silicone the header back on after replacing the o ring.
  6. Tentontimmy Husqvarna
    Caribbean
    2012 WR125
    Suzuki GSX-R1000
    Thanks for the replies, everyone.
    Will try re-sealing the pipe. These bikes (2012 WR 125) run a single metal o ring, right?
  7. Oldscool Husqvarna
    South Australia
    None
    RM125, SWM RS500R & Superdual
    No mate. They run a normal type o'ring in the groove on the pipe and a steel washer where the pipe seats against the barrel (at the end of the pipe).
  8. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    My 150 was messy at the exhaust manifold. When I did the 165 I found no steel washer, so installed a new one with a few blobs of hi-temp silicone to hold it in place. New o-ring too, no more mess so must be sealed up well.
