exhaust paint. best products?
Discussion in 'Vintage/Left Kickers' started by megagobby, Oct 20, 2010.
  1. megagobby Husqvarna
    im looking at spraying my 250 front pipe. as you all know it gets very hot. just would like to know what is the best product on the market for long lasting finish?. im looking at pj1 withstands up to 500f . would this be ok ? maybe it would burn off in time ? any ideas thankyou all:thumbsup:
  2. megagobby Husqvarna
    i have seen another. vht caliper paint which withstands up to 900f . i dont really know how hot exhaust will get so i dont know which tempature to go for
  3. White Husky Husqvarna
    UK
    Painting the exhaust is on my list of things to do. The paint on my XC500 header burned straight off on its first run so I'd say it gets very very hot. Bear in mind it's still hot enough to melt side panels by the time it gets back to the stinger.
    I think PJ1 do a fast black paint rated to 816 Celsius. That's what's on my Christmas present wish-list!
  4. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    Actual i've been using regular semi-gloss Rustoleum on all my racing bikes. I start them up & run them for a few mins when i put them back
    on the bike,to dry the paint totally.
    Then I use Meguiars Natural Shine , sort of a Armour All type spray. This stuff is the greatest stuff since sliced bread, spray it all over the motor, makes it look great & it's not greasy like Armour all & doesn't leave stains when you wash the bike.
    My painted pipes easily last a couple of seasons, most needs repainting
    from dirt & rocks beat the paint up,then from heat. Maybe it's the Meguiars i don't know,but for my race bikes $4 spray paint sure beats
    $10 for the high temp stuff.
    here's my 83 XC
    Husky John
  5. rajobigguy Administrator
    So.Cal.
    VHT header/exhaust paint can withstand 1300 degrees intermitent. If you really wan to keep it nice for a long time you should consider having it aluminized or ceramic coated. The ceramic coating will also keep more of the heat inside the pipe which is potentially good for performance and helps reduce burns.
  6. wrx Husqvarna
    845 newyork
    1973 to 1986 husky's various models
    RM -250 / Buell / Penton 400 mc5
    RUTLAND STOVE PAINT. can be purchased @ lowes or home depot. $8.00 a can.
  7. frog Husqvarna
    MN
    I love PJ1 high temp paint/coatings just turns out great every time!
  8. megagobby Husqvarna
    im going to give , simoniz vht it withstands 1200cf . and i will let u know how it goes thanks all :thumbsup:
  9. endurokids Husqvarna
    Wisconsin
    250WRX, CR167, 83 430WR, TE449
    75 Guzzi 850T
    I have all of my pipes ceramic "jet coated".
    Ive raced my 83 XC250 for 3 years now and its only now starting to show signs on the head pipe area. About 85% looks new still.
  10. mike328 Husqvarna
    colorado
    I just restored my '71 400 and HT semi gloss was used on the expansion chamber.. I 'seasoned' it ..let engine run & dry etc...
    been riding it maybe a couple hours and the paint is getting a dull look, will probably need painting again in a yr or so..
    additionally I had my Bultaco alpina exhaust ceramic coated..yes it holds heat in, but its a very thin coating and really not durable for motorcycles...(cars yes) but exposed pipes going thru bramble bushes etc...scratches/damages exhausts
    my opinion: The ceramic is more durable but costs more..and when weighing the difference and the frequency refinishing will be needed...
    I think paint is preferred..
    I have photos of the exhausts on my restoration thread: http://www.cafehusky.com/forums/showthread.php?t=11439
  11. megagobby Husqvarna
    do you have any pictures of the ceramic coatings ? iam looking into getting mine done. just would like to know the finish. does it have to be polished up after? not too sure of process. thanks
  12. mike328 Husqvarna
    colorado
    I had my alpina exhaust coated in Satin finish.. you can see it in my post..I attached above
    Also check out this site,,
    http://jet-hot.com/
  13. Parh 474 Husqvarna
    Newbury Park, CA
    '73 Cr125, '06 Cr125/144
    Ossa, Bultaco, Puch, Maico, AJS, Yam
    I've been using VHT Cylinder paint. Works well, goes on semi-gloss and goes a little more matte after it cooks a bit. Looks factory with the semi flat finish.
  14. mike328 Husqvarna
    colorado
    Parh...What Brand?...also do you have any links to find it?
  15. HuskyT Moderator
    Corona, California
    Where do you get the VHT in California? WHo carries it?
    T
  16. rajobigguy Administrator
    So.Cal.
  17. stainlesscycle1 Husqvarna
    morgantown, wv
    i've done ceramic/vht/rustoleum bbq paint on various bikes. bang for the buck - the rustoleum works great for 1-2 years. the ceramic lasts a long time but damage is impossible to touch up. if i'm gonna ride it - rustoleum or vht. if it's for restoration (of course not period correct) ceramic coat.
  18. Parh 474 Husqvarna
    Newbury Park, CA
    I get it from Chaparral in San Berdino. I think they actaully call it VHT Barrel paint. Its got a picture of Triumph barrels on it.
  19. megagobby Husqvarna
    i think i have found it on fleabay. is it 288oc paint ?
  20. Green Mile Husqvarna
    1984 WR400
    198? XC250
    i just picked this bike up is this a xc250 and what year
