250-500cc Exhaust Port WR360 92 - 2002
Discussion in '2 Stroke' started by icebergstu, Nov 6, 2010.
  1. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    Does anyone know if the exhaust ports and mounting points are the same diameter through the life of the 360.
    The reason I am asking is I want to retro fit a 2000 model FMF expansion chamber to my 92 model.
    Will I have any dramas?
    Stu
  2. timpjr Husqvarna
    Sparks, NV
    93 WXC 360
    EVT America 3000w Scooter
    360 Exhaust
    The Motors are the same as far as I can tell from part numbers, they have changed frames several times so the mounts and pipe curves may be different. This really interests me as I am about to start hunting for another pipe myself. If you go through with it let me know good or bad. I have a 93 WXC360
  3. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    No probs.
    I will order one this week so in a couple of weeks I will start the thread.
    I can see that the 2000 model has different anchor points but as long as it seals at the head and doesnt leak then the rest should be easy with a few mods here and there.
    I will also get an FMF shorty muffler too and Retro Fit that.
    Stu
  4. timpjr Husqvarna
    Sparks, NV
    93 WXC 360
    There are still FMF Gnarly pipes made for 92 and 93 why not go with that, did you look at the FMF website ?
  5. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    Yeah I did.
    They only list 2000 - 2001 and 2002 which is why I was going to try the retro fit.
    Stu
  6. rancher1 Husqvarna
    WA
    The 92 360 used a different system for the exhaust. The 1993-2002 are the same. I would caution you on the 1992 you may be wasting good money. The cylinder/exhaust is very different on the 92.
  7. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    Thanks for the info mate.
    Can you elaborate a bit?
    You say that they are different but any idea what is the difference?
    Is the exhaust port size different?
    Is the way it secures to the head different?
    Is the shape different?
    Are the mounting points different?
    If my bike is an 11/92 build then is it a 93 or a 92?
    How would I distinguish between the two models?
    Stu
  8. timpjr Husqvarna
    Sparks, NV
    93 WXC 360
    The cylinders have different part numbers between 92-93 but it looks like the real difference is the 92 has a male adapter on the cylinder with a matching pipe (shorter at the head) and the 93 does not the pipe goes straight into the head. Does your bike have this adapter? Could be that the adaptor method was changed to save weight, better design ? I think if you look up just 360 instead of wr360 on the fmf website you'll see the 92-98 model pipe
  9. rancher1 Husqvarna
    WA
    Correct on the mounting difference between 92 & 93
  10. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    pics...pics... :)
  11. timpjr Husqvarna
    Sparks, NV
    93 WXC 360
    92 and 93 wcx 360 jugs
    Heres the pics.....
  12. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    #1 shows the mount
    #2 shows nothing???
    36, 37, 38, 39 are missing?
    What am I supposed to be looking at? :excuseme:
    Stu
  13. rancher1 Husqvarna
    WA
    # 1 is a 1992, # 2 is a 1993. The pipe for a 92 goes over the outside of the mount or as you call them the missing pieces, the 93 pipe slides into the cylinder like most bikes.
