Exstended Shifter?
Discussion in '610/630' started by buster1234, Apr 29, 2014.
  1. buster1234 Husqvarna
    Te630
    Triumph trophy
    Hi new to forum. Was wondering if anybody make a longer shifter. Thanks
  2. Ross Shafer CH Sponsor
    Petaluma, CA
    2006 SM610
    KTM 950sm, Honda XR100
    Hammerhead makes offset shifter tips. The MX boots I ride in made shifting difficult with the stock lever on my 610. I got the Hammerhead tip with the most offset (20mm I think) and it's much easier to fit the clodhoppers in there. The offset the shape requires that you swing your foot outward a bit more to engage the offset portion of the tip. Very natural to do in the boots, but a slight annoyance in street shoes. The install is not a slam dunk. I don't remember for sure what was needed to make it work, but I think it required using the stock spring and drilling the lever for the larger Hammerhead pivot.
  3. BiG DoM Husqvarna
    Yes the HH tip is the way to go. Well documented if you do a search here.
