125-200cc F size cylinder/piston?
Discussion in '2 Stroke' started by shawbagga, Dec 28, 2017.
  1. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    No other markings. Thought they only went A-D. Came with an A piston second hand. image.jpg
  2. tmmyghst Husqvarna
    Corona,Ca
    Nice toe ring by the way.
    shawbagga likes this.
  3. rancher1 Husqvarna
    WA
    What year and model is the cylinder from ?
  4. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Dunno mate I'd say one I'd the early 7 port ones as has bigger PV's with drain hoses. Not sure when they went from 5 to 7 port?
  5. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    so spare 125/144 cylinder? Not your 165? Didn't know there was an F either.
  6. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Yeah older 125 top end. I can only find D size pistons?!
  7. rancher1 Husqvarna
    WA
    Okay, here you go, husky used to size cylinders A-B, C-D, & E-F, these would be equal to today use of A, B, & C. In other words your old "F" cylinder is equal to a "C" today. That is why I asked the year of the cylinder. In reality you can use any piston in any cylinder as you saw with an A piston in the motor.
  8. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Check the ring gap with the new parts! :cheers:
  9. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Ahh rancher you are the man! Appreciate ya passing on the info mate. I was actually thinking something along those lines(probably read it here before!). Thanks mate. The A piston it came with feels a little sloppy in the bore? Might just be me though.
    Old ring that came with it was 0.5mm about 10-15mm below top of bore(pushed in square with piston). Was thinking 125 should be around 0.3-0.4mm?
  10. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Looking on ebay mitaka list A-D with 2 O/S pistons:
    A-53.94
    B-53.95
    C-53.96
    D-53.97
    O/S-54.50
    O/S-55.00
    Might see if can get cylinder mic'd otherwise I'll just run with a D
    NCSteve likes this.
