factory lamps to Acerbis X-LED wire-up
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by pvduke, Nov 2, 2014.
  1. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    first of all, the back of the mountain bike shop was turning into a dark dungeon catch-all. it [was] a nice space with cabinets and a nice counter top.. and then dim bulb kinda flickered, sputtered on and....everything got the boot!
    before (sad):
    after! (pardon the stain, it's gear lube from the ATV shop- those dont come out):
    Goal- to get the Porkinator plated- not hard to do here. I (finally) installed the factory "gift box" of goodies (no diagram, grrrrr) and got the front bits all sorted out, popped the mirror back on too. i've seen the Acerbis X-LED on another bike and thought it would look really sano on the Hoosk. first, mount the light/plate holder after a tiny trim job of the ribs in the fender- i used a dremel. wire up yellow to yellow, blue to green and tuck 'n tape the blue Acerbis lead back if you don't have a brake light switch. the wires were way different diameter so i braided them (i dropped the solder gun and it's dead- dang it!) and double-heat shrank it all using a pencil torch, not a heat gun. (cover the air filter kids, or else!) a tiny pencil torch works great in tight spots on low- just wave and shrink. (pardon the soot).
    Centerline likes this.
  2. pvduke Husqvarna
    ... on the gas...
    route yer wires logically, index your screws and fire it up. it's awesome. has a plate lamp too and works on almost no voltage. it's also from Itallia!
    i trim all my ties with a nail clipper flush to the zipper-head. no cuts that way.
    i did some experimenting with and without that resistor thingy or whatever it is. the head lamp is brighter with it so i safety-wired it to the "tail" on hose clamp on the head so it would stay cooler and not heat the wires under the tank, it gets HOT. i also just noticed i need to change my brake fluid- it's TOAST! lol.
    got it smack in the middle somehow...lol. usually these things tend to be whale-tails, this one is tiny and the photos dont do it justice.
    Motosportz, Centerline and 268fords like this.
  3. pvduke Husqvarna
    ... on the gas...
    neat as a pin....looks factory too!....figure if im going to all the trouble to install the "gift box" goodies, why not spend a couple bux and get a nice rear lamp and plate holder!
    bright as all get out...note the white LED plate lamp for DOT compliance.
    the Porkinator is a happy camper in his new spot and we are ready for inspection. yay
    momma-mia! what a great lamp and plate holder...it really is nice i am super stoked about it. that's all folks! braoooop!
  4. Centerline Husqvarna
    Texas
    2007 TE450
    HD Fat Bob, Aprilia Dorsoduro 1200
    Great photos and good explanations matched up with them
    pvduke likes this.
  5. Big Timmy Husqvarna
    (South Eastern) AZ.
    Nice,
    What I want to know is? Is that your Enduro cross training area outside the window there or just a big pile of tires you could be riding on?
    pvduke and Centerline like this.
  6. pvduke Husqvarna
    ... on the gas...
    yes and yes! logs and rock pile are just before the tire pile...and they are filled with barbed wire n broken glass, good incentive not to stall! lol....
    Huskynoobee, Centerline and Big Timmy like this.
  7. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    Glad your Chinese shark egg is working for ya. It finally stopped dropping goo I hope. Nice write up duke!
    pvduke likes this.
  8. pvduke Husqvarna
    ... on the gas...
    thanks HN! yeh, hanging it out in the breeze did the trick. we did some insane hard stuff this weekend, 15 hours or so (and a sprained thumb 5 miles in, darn it!!! , made for a LONG day)....not a drip.
    here's the new get-outa-jail-free card mounted. i used big patches of mongo-strentgh Velcro to mount it and set the glue off with a heat gun on low. then pop-riveted some vanity plate bolt cups (bolts are too heavy, wanted to really keep the weight down) then snapped on the 'disco-crystal' caps to cover all the holes. BLING-BLANG! lol.
  9. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    Sweet! Much less weight than one of those bling encrusted plate frames. AZ is a wonderfully free place...folks are friendly and admire each other's sidearm, you can plate a 2 stroke. I can almost remember when Kali was like that...oh wait, no I can't.
    pvduke likes this.
  10. pvduke Husqvarna
    ... on the gas...
    lol....i can....but we still had to run from 5-oh in the classy parts of town....lol
