Fat Bar mounted on 83 XC
Discussion in 'Vintage/Left Kickers' started by mattskn, Dec 25, 2008.
  1. mattskn Husqvarna
    Bay City, Mi
    Found a way to mount 1 1/8 bars on my 83 XC250..I was looking at my parts bike 05 YZ250 and noticed that the applied triple trees on the bike looked very similar to the ones on the husky. I took them off and sure enough the bar mounts worked great in the husky top tree, here is a pic of the set up..I bought the applied trees off ebay for $30 a couple of years ago...
  2. flyarmy Husqvarna
    Oregon City, OR
    Mattskn,
    Great idea also. Did you need to modify the hole diameter in the existing husky triple clamp? Are the handlebar mounts still rubber mounted? The only disadvantage I can see is in the adjustment upward of the forks up in the clamp. I like to run mine about an inch up in the top clamp for tighter steering. Maybe raking the frame as in your other post might take care of this? The fat bars are much better than the old style and will make it look very original. Thanks. Mike
  3. mattskn Husqvarna
    Bay City, Mi
    If you take the rubber covers off there is about 3/4 of a inch to play with..Yes the mounts are still rubber gromets. I popped the husky one out and popped the new one in just that simple..Have you messed around with the fork position in the clamps? Im looking for feed back on suspensionn set up.Ive hears the 87 internals with 83 legs are the way to go do you know why...Is there some special dampening in the 87..Is that the last year for the 40mm fork?
  4. flyarmy Husqvarna
    Oregon City, OR
    The way I understand it, the 87 and 88 40mm standard fork internals had a cartidge or valve style damping system with top out springs instead of washers like we have currently. I believe the 88 WR was the last year for the conventional fork. The guy at Husky parts Australia has a modified damping rod and valve set up that he says makes the 40mm husky fork like a modern fork. If I remember, the price would be around $300-350 US dollars for the kit. I run my forks about an inch up in the clamps for tight tracks. It helps the turning but with a modified frame, it is hard to tell where you want them. My forks are 37 inches from the axle center to the top of the tube. I was going to use a set of 83 YZ490 43mm forks and they were 36 inches with the same measurement. The triples would need to be bored 3mm in order to make them fit. I don't really know enough about rake and trail to tell anyone what the best set up is. I just want my husky to turn and handle like a Maico. The Ohlins are sweet and the forks so so. Please share any thoughts on this.
    Mike
  5. oregontrail Husqvarna
    Jacksonville, Or
    2012 350 XC-f
    1999 Buell X1 Lightning, 2004 KDX220
    I ran fat bars on my 430 back when I started vintage racing, really helped with arm pump. :applause:
  6. mattskn Husqvarna
    Bay City, Mi
    There is a set of 87 forks on EBAY and I was thinking about getting them, there $50 buy it now..
  7. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    Is there a rubber insert from another bike that swaps in well? The original husky part is getting hard to find.
  8. mattskn Husqvarna
    Bay City, Mi
    06 or newer YZ
  9. Picklito Husqvarna
    Washington
    Thanks! I guess what I was asking is whether the actual rubber cones are Yamaha pieces or Applied pieces? I'm probably going to keep the 7/8" husky bar mount but need new rubber pieces, and the husky rubber inserts are hard to find and/or expensive. Thanks again.
  10. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    Hey Picklito.
    I just ordered a set of handlebar rubbers from a guy named Gerald in Mich.
    He also sell new brake rods and peg springs, i bought all 3.
