Faulty Indicators
Discussion in '610/630' started by Gav, Jan 12, 2013.
  1. Gav Husqvarna
    West Sussex, United Kingdom
    SM610
    GSXR 600 SRAD:Sold ZXR 400 H2:Sold
    Hi all
    I'm having some issues with my indicators on my bike.
    Went for a off road blast last weekend in the wet and mud. Great ride :D
    Anyhow come to use my bike today and the indicators aren't working at all.
    Is there a wiring diagram for the indicators somewhere ?
    Is there a common faulty part, fuse, flasher unit etc that is likely to be the culprit.
    Might just be a dodgy earth but I'm not sure where to check.
    Thanks
    Gav
  2. 1lunger Husqvarna
    Bloomfield CT
    I would check under the tail section. Lots of crap will get in there when in the mud. Remove the whole tail light section and clean up the wires.
  3. Gav Husqvarna
    SM610
    Yeah I gave the bike a good clean this weekend.
    There was quite a lot of mud up on the tail section, which I cleaned off. The fuse boards seemed to stay pretty clean and can't see any blown fuses.
    I've also ordered a set of Indicators and relay from fleabay just to test if the relay has gone.
    Not sure how else to test this ?
    Is there a wiring diagram available for the indicators / flashers ?
    I imagine they just run off the switch gear on the bars to a relay and switched 12v / ground.
    I don't imagine they go through the ecu do they ?
    However I recall they only work with the engine on so what would do that ?
  4. Gav Husqvarna
    SM610
    Looks like its a bad relay!
    Bought a set of indicators and relay from fleabay and they are at least lighting up. Need to change all the wiring and find somewhere to stick this relay now. :( Tad on the large side to fit where the OE one was.
    Also on the same ride the rear tail light blew, got water damaged.
    I've replaced the bulb, but the brake light isn't working. Shall take a look in detail at the weekend when I get a heater in the garage. Far too cold at the moment
    Not having much luck with the electrics at the moment ! Also the wire they used for this bike is rubbish! so brittle
    Does anyone know what the fuses are for on the bike ?
