FE/FC FC350 Suspension tuning & Sag
Discussion in '4st' started by TX0500, Jan 29, 2017.
  1. TX0500 Husqvarna
    El Cajon, CA
    TX300 FC350
    kx500
    Hi guys,
    I'm in need of some recommendations from expertise's
    I did my static and full geared(stand up) sag, Im at 103mm now
    first question is: standing up or seating down for measuring?
    most you tubers say up but a few say seating down (service manual picture shows on the seating position)
    The other advise Im looking for is:
    I just did the revalve(motocross) on my weight springs specifications, etc... with a local suspension guy, went for a 1st ride test and all was well except in a couple of clean exiting jumps...rear wheel was kicking side ways…I'm thinking it could be something simple with reb & Comp tuning…any advise will be great,
    Thank you in advance.
  2. octagon pilot Husqvarna
    Desert Southwest
    2015 FE501s 2009 TE610
    YZ450FX Tenere 700
    I've always done seated.
    I'd also say you need a bit more race sag than 103. 105-112 is the range I see recommended and I'm at 108 for my personal preference.
    For the rest, experiment (might try less HS comp, and/or slower rebound on the shock) , or talk to your tuner guy for input.
  3. TX0500 Husqvarna
    El Cajon, CA
    TX300 FC350
    kx500
    Thank you Sir for your input…I will try more open sag
