FE/FC FE 350 FMF Exhaust?
Discussion in '4st' started by Adam Crookes, Apr 13, 2014.
  1. Adam Crookes Husqvarna
    2014 FE 350
    Does anyone know if any of the KTM model's exhaust bolt on? The Canadian distributor's are talking about August before any exhaust shows up from FMF. Head pipes seem to be available, but not the muffler's.......
  2. Colo moto CH Sponsor
    La Jara, Colorado
    7602racing.com
    Just taking a shot in the dark here, but the reason they may be telling you that only the headpipe bolts on is because of the different subframes. Possibly the mounting locations have moved?
  3. 310huskyTE Husqvarna
    Melbourne Australia
    2014 FE 350, 2011 Meo.
    67 CR250, 71 400 Cross, 78 CR250
    The distributor is telling you lies.
    This fits all the four stroke range and is available at my dealer now!
  4. Toom038 Husqvarna
    Central Florida
    '14 FC 450
    RC 51
    I asked an FMF employee at the Daytona sx about KTM pipes fitting. He said they had some issues with the pipe melting the subframe and would have Husky specific pipes soon. I checked their website the other day and they do have different part numbers for a FC 450 now. That being said, I am in the process of removing the internal baffle in my stock muffler (MXA said it helps the bottom) and while I had it off I slipped on my old '07 450sxf stock muffler. I bolts right up. Gonna run it to see if I notice any difference.
    BILLF likes this.
  5. Adam Crookes Husqvarna
    2014 FE 350
    Thanks for your help guys!! I got my exhaust on order. I talked to the guys from FMF on Monday, they said it should all work. They did say that there going down to a hand full of new part numbers that will fit them all. So I guess that's why the dist. was saying Aug. That would be for the "NEW" part numbers.
  6. Dangerous Dan Husqvarna
    2014 FC 350
    I also have an FC 350 and i too was told August. Also I was told that the 250 runs the same exhaust system. On the FMF website I can find listings for the FC 250 and 450 but only FE 350. Am I correct in assuming the FE exhaust will fit fine?
  7. CAD Husqvarna
    Perth, Australia
    FC 350
    Gas Gas TXT Pro 300
    I am also curious as I have noticed the exhaust same thing... and I really want the FMF full system... Don't know whether to buy the FC250 or the FE350 version :(
  8. bowser Husqvarna
    FE350
    FYI I fitted up a FMF 4.1 muffler from a 09 berg 450 to my FE350 without any problems. Matched it to a KTM SXF mega bomb header from memory.
    best way is to go to a KTM website that has the part catalogue and cross reference the 250 to 350 etc for the various KTM models and then that will tell you which models will be the same and therefor fit your Husky. KTM are pretty good for not changing parts between models and years which makes it easier to get secondhand parts etc
  9. SM113 Husqvarna
    Oregon U.S
    Soon to be 2015 FE 350
    Just got mine the other day, dealer actually found part numbers just fine
    Muffler says KTM SX-F/XC-F- 07-14 /XCF-W 08-14 /HSKY FE250/350 14 part # 045558
    Power bomb header says:
    KTM250XCFW'14/350' 11-2/XCF'11/XFFW'12-4/EXCF'12-4/HSKYFE250/350'14
    Part # 045365
    CAD likes this.
  10. CAD Husqvarna
    Perth, Australia
    FC 350
    Gas Gas TXT Pro 300
    Would a full system from the FC450 suit the FC350? I think the part numbers are different so I'm assuming not.
  11. BILLF CH Sponsor
    BMP Husqvarna, Salem, OR USA
    92WXC350 /Lamson CR250/701 Vitpilen/
    Triumph900 Scrambler 1200 HD Nightst
    iM RUNNING THIS ON MY FE250 WORKS GREAT
  12. SM113 Husqvarna
    Oregon U.S
    Chad
    Same muffler diff. Head pipe
  13. CAD Husqvarna
    Perth, Australia
    FC 350
    Gas Gas TXT Pro 300
    But the 350SXF and FC350 FMF exhaust are the same? Awesome.
  14. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    2 totally different engines.
  15. SM113 Husqvarna
    Oregon U.S
    Yup 8-)
