FE/FC FE 350 MAP SWITCH
Discussion in '4st' started by motomanic, Aug 24, 2015.
  1. motomanic Husqvarna
    England
    Hi, have recently bought a FE350, I see Husky sell a two position Map switch which I believe switches between maps on the ECU. Trailtech sell a 3 position switch which changes the timing?
    My bike is uk spec, my questions are; am I corrects to the type of switching? Whats best, and does the ECU require remapping for the Trailtech switch.
  2. bikesparky Husqvarna
    Townsville Oztrailia
    FE501
    Superduke 1290
    Normally UK, EU and Australian models have the maps build in. The switch changes the ignition map. The trailtech one gives you standard, hot and tame.
    I believe '16 models have the switch standard.
    Trailtech works nice as the switch also replaces the kill switch, basically it does the same as the original one.
  3. bowser Husqvarna
    FE350
    get the TT one, works great
    reveille likes this.
  4. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    Another trailtech vote here. Mine works great and incorporates the kill switch. Easy install and clean.
  5. motomanic Husqvarna
    England
    Am I correct that the TT alters timing and plugs in behind the headlight, no downloading of maps required(uk). If they do different things, would they work together?
  6. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    It plugs in under the seat near the ECU. Easy peasy. I had to have my USA model flashed to the EU spec to allow the switch to operate. You're all set in England, I'd imagine.
  7. motomanic Husqvarna
    England
    Reveille, are we talking about the Tourtech 3way switch plugging in under the seat? If so does it plug in , in the same place as the Husqvarna 2 position switch?
  8. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
  9. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    just throwing info, which I don't have too much of. ZipTy Crew just installed a dual map switch to crew member Andy's FMF/PC5 equipped FE350S so he can go from 350 bullet train 50 mile mode to S 90 mile mode
