FE/FC FE250 Map Switch
Discussion in '4st' started by Hoov165x, Apr 28, 2015.
  1. Hoov165x Husqvarna
    Carlton, OR & Sunriver, OR
    The Latest: 2014 FE250
    Has anyone here had their ECU reprogrammed for use with an adjustable map switch. If so, is there a significant difference between settings? This question is only for the FE250.
  2. Weantright Husqvarna
    Burton, Oh
    2019 FX350 w/KYB Inserts
    2017 FE250 w/OC, 2016 XTrainer w/KYB
    We looked into it but felt it wasn't needed since it's a 250 and we are not "A" class rider. Also I was told you have to have the throttle close (idle like coast) for the map switch to change maps. Instead added a FMF exhaust and the bike has more smooth power from idle to top. You will need one of these if you reprogram the ECU. Start here first.
  3. Husky-Nut Husqvarna
    Connecticut
    1983 WR250, 2020 FE501
    1931 Indian 101 Scout, 1936 Chief
    What FMF exhaust did you put on? Did you keep the stock silencer, or did you change that also?
  4. Weantright Husqvarna
    Burton, Oh
    FMF mega bomb w/4.1 RCT muffler.
