Final Answer about pick-up coil
riccardo
Hi to everyone, I want to share with you what I found out about the pick-up coil... I've searched around various forums, and contacted a few sellers.
This item should works for each Smr/Te model (04-07-08-09-10), but I suggest you to check the correct value on your workshop manual. (it should be 100 ohm +- 15%).
There are 3 options:
-buy the original part
-buy a replice
-buy a new(or used) stator
Here, there is the label with different pick-up coils:
The P01 is the correct one.
As you can see on the site, this part is used for a lot of KTM models... so I've checked the exploded drawings of 3/4 different bikes, and the spare part was the same.
So if you want an original part because you don't trust replica, the part number is: 59039034000
I bought it for 74€ (in italy... maybe the costs are different in other countries).
But if you don't care about original part, in order to save some money, there are two well know resellers:
- horse power ignition (https://www.hpi.be/pickup.php "P01")
-regulator rectifier (Pickup Coil SMR510 Husqvarna (regulatorrectifier.com) I've red some bad reviews, but nothing serious)
"horse power ignitionis" is situated in Belgium, so convenient for europeans (but if i remember well, somewhere is written "shipping all over the word" or something similar) .
While "regulator rectifier" is situated in US.
So, I hope this can be useful for someone, and if anyone wants to share any info about TC-TX models, it is welcome.
ps: probably there are a lot of mistakes or syntax errors
