Finally found the crash damage! Rear sprocket.
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Cosmokenney, Sep 30, 2014.
  1. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    After taking a hard fall in a rock garden, I was wondering how my bike came out without a scratch. It wasn't until I washed it today that I found out why. The rear sprocket took the entire hit. It's bent and the chain snaps (loudly) as I rotate the wheel.
    It's a renthal aluminum. I've got a trip to Nevada starting on Thursday night. No time to find a replacement 52 on line and have it shipped.
    Can I bend it back? Or should I put the stock 51 back on?
  2. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    If it was me I'd put on the 51 and go ride.
    Cosmokenney and Tinken like this.
  3. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    We might be able to overnight one to you, have tons of sprockets in stock. Eventually, I would get a DirtTricks Ironman sprocket. It can take hits like that and will not break.
    Cosmokenney likes this.
  4. ray_ray Mini-Sponsor
    The Philippines
    Can you bend it back? Not sure but if it was mine, I'd try unless it is impossible to get straight again ... But also purchase a new one. Myself, I don't buy the ALUM ones any more due the steel or hybrid ones lasting so much longer ... I tried a 51T once instead of a 50T ... I could not tell the difference when riding really...
    I slow down in the gnarlier rock places here that can damage the bike... same as the deeper water stuff ... I just avoid these places and try to eliminate self-inflected wounds as much as possible. Not enough time left to be sitting when I should be riding ...
  5. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Ray, I can't help myself. The 511 is so much fun with the pcv, I just can't stay off the throttle. I can see now that I need to send it to ZTR to get the suspension revalved. I put new springs in, but the front wheel keeps squirting out from under me.
    Tinken likes this.
  6. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Is the BMW G450X sprocket the same?
  7. Motosportz CH Sponsor
    Don't run it put the other one on.
    Tinken, Cosmokenney and robertaccio like this.
  8. rancher1 Husqvarna
    WA
    No they are different in the back.
  9. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    This is so frustrating. I have a so-called Husky dealer and a KTM/Husky dealer within 15 minutes drive. No one in town has these in stock. :thumbsdown:
  10. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Just run the oem one. Not worth getting hurt or stuck in the middle of nowhere.
    268fords likes this.
  11. Dangermouse449 Husqvarna
    Sunshine Coast QLD Australia
    2011 TE449
    2009 CRF450R 2000 YZ125
    Pull it off, place it on some hardwood & carefully tap the bent area straight with a plastic hammer (or regular hammer & block of wood).
    Inspect for any signs of cracking, refit it & order the new one.
    Personally, I'd ride on it if it meant not missing a ride.
  12. Alberto Husqvarna
    Costa Rica
    2011 TE250
    what is the price for one of them, say 50t? I mean dirttricks Ironman?
  13. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    From Zipty, about $95 dollars with your Cafehusky discount.
  14. Alberto Husqvarna
    Costa Rica
    2011 TE250
    sounds a good price for that quality sprocket, when mine is going to need replacement, I will order one of yours
  15. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Do the MY12 TE's run the same sprocket as the MY13?
  16. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Same sprockets MY11-14 TE/TXC/TC 449-511.
  17. huskylove Husqvarna
    norcal
    1999 cr125 in progress
    I would replace the sprocket AND CHAIN if it was run at anytime at all like that.
    I have some nice pictures of a friend in your situation that tried the save a few pennies route.
    Lets say broken chain, lots of missing skin allover his body and a few broken ribs.
    Drivetrain, brakes, and tires. Do not f%# around.
    268fords and Tinken like this.
  18. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    What are the specs on our chains? 520 something or other? Who makes a decent/affordable chain?
  19. huskylove Husqvarna
    norcal
    Any of the big name brands, RK, EK or DID are what I use. Clip type link with sillicone over it, or rivet by using a c clamp and ball bearing.
    Up to you. I am super super super particular about drivetrain and brakes. Never had an issue but it could easily be a problem.
    I just know way too many guys that run worn out sloppy loose chains or bald tires or ebay brake pads. I cant do it :\
  20. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Is this what I want, or can I get away with the 114 link?: http://www.amazon.com/DID-520VT2-12...d=1412289576&sr=8-4&keywords=d.i.d. x-ring vt
