First casualty, needs some help
Discussion in '610/630' started by Muddy Waters, Aug 28, 2010.
  1. Muddy Waters Husqvarna
    On the islands
    :( I knew this day would come...and here I am...on this day...that came...
    My 610 ejected one of its heat shield bolts along the way :bonk:
    So where can I find those bolts, anywhere special or my local automotive store aka NAPA ?
    :cheers:
  2. Doormandan Husqvarna
    So Cal
    Take them off (LOL) I ended up making a shield for my leg but the rest were not necessary. Some were I also saw some carbon fiber shields that looked great. As for finding bolts I would bet a fastener supply house would have a metric allen bolt that would look the same or very close.
    Dan L
  3. K7MDL Husqvarna
    Woodinville, WA
    They are just regular metric bolts. Nothing fancy. Local stores should have something suitable. Take out the other one for an example. If you can only find longer ones, use a hacksaw to cut it shorter.
  4. Blazes Husqvarna
    South Africa
    Eddie Seel 634SMR works Replica -
    Aprilla Dosodoro 2X 2009 610
    The same one i lost on my 610te--Luckily i had a Arrow pipe fitted and could take the one from the heat shield on my original exhaust off to replace it--Making carbon fibre heat shields for my bike and will fit stainnless button cap bolts in later--
  5. Flying Trash Can Sustaining Member
    So. Cal
    TE 610
    BMW R1100R
    I doubt you'll be able to find a decent replacement at NAPA. If you lost the whole thing then you should go to a place that specializes in metal fasteners and find one that matches the rest.
    If you still have the metal clip that the bolt threads into then you can use one of spare bolts from the "smogectomy" that most of us perform. That's how I fixed mine except I also used a felt washer between the two shields to keep the thing from rattling.
  6. Muddy Waters Husqvarna
    On the islands
    Thanks for the reply's guys
    Very helpful, I’ll try to find it in the local stores and cut it if I need to
    Flying TC; you scared me a bit, talking about losing the whole thing and if I still have the clip…
    So I took the front part down to see what did I lost and what do I still have
    It turns out the clip is on the front bolt and it doesn’t seem like you can lose it but just to be on the safe side I’ll just leave that part down till I find a bolt
    Thanks again folks :cheers:
    :thumbsup:
  7. miketv Husqvarna
    Columbus, Ohio
    I ended up just removing the front shield and the mount on the pipe all together as it really isn't needed. Plus, if you ride anything really tight with alot of brush it just catches it all and trys to rip off anyway. I just ordered the OEM screws from Halls, had them in a couple of days.
    FWIW, the only way I could get the shields to stay tight was to use a "star" type locking washer under the allen cap screw. DO NOT try and tighten the heck out of them as they seem to be made of butter and can round out really easy. (guess how I figured that out) :banghead:
    cheers,
    Mike
  8. Flying Trash Can Sustaining Member
    So. Cal
    TE 610
    BMW R1100R
    Muddy, my memory is a little fuzzy sometimes. :excuseme:
    I did find the right sized factory bolt in my spare parts box. It's a left over from when I replaced my factory pipe. Let me know if you want it and if it's something I can mail to you.
  9. Rokon Husqvarna
    Tacoma, Wa.
    If you don't cut it to the right length you'll get an irritating exhaust buzz.
  10. Muddy Waters Husqvarna
    On the islands
    Awesomeness !!!
    Love this site
    Got an envelop from the :notworthy: FTC headquarters
    Flying Trash Can thanks a lot pal :applause:
    Hopefully I’ll be able to repay or pay it forward
    :thumbsup: (It’s the little things that make me happy )
  11. oregonsage 4st Clerk
    Dry Washington
    FX450
    Yamaha DT400 x 2, BMW G310R
    Bills Husky has the carbon fiber heat shields. It looks sharp .... saving my pennies.
  12. Flying Trash Can Sustaining Member
    So. Cal
    TE 610
    BMW R1100R
    Cheers Muddy, :cheers: Always glad to help a fellow rider out.
