Fitting a Magura Mineral Oil clutch to a Brembo brake fluid system
Discussion in 'General (Main)' started by STEVEL, Feb 17, 2014.
  1. STEVEL Husqvarna
    U.K
    TXC 250 2013
    KTM450 EXC 2006
    Hi i want to fit a Magura 1 clutch master cyclinder to a TXC250 2013 so i can use my Midwest Mountain lever, trouble is the Brembo uses brake fluid and the Magura is Mineral oil!
    Does anyone know if i can use and what fluid should be used also
    Thanks in advance
  2. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    MME makes a Brembo lever.
  3. STEVEL Husqvarna
    U.K
    TXC 250 2013
    KTM450 EXC 2006
  4. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Right I know someone is going to have fits over this but around 4 years ago I mixed a brake fluid system with a mineral oil setup and after the master clyinder seal swelled so bad it all went tits up. I rebuilt the master cylinder and used good old sun flower cooking oil for the system !! Sold the bike to a mate that still has it and its never been a moments trouble and works as smooth as the day I put it all together and has as far a I know never even had a top up or fluid change.
    Its entirely up to you but it will get you over the problem and works really well unless someone else has a better idea.
    It dosnt matter what way you go with brake fluid vs mineral oils both will swell seals that are not designed to be used with.
    duggoey likes this.
  5. duggoey Husqvarna
    NSW, Australia
    2010 TE 310
    KTM 690, Yamaha WR200, FGS650(800cc)
    I have used a couple of different fluids, I agree with you about swelling. Only thing is the return action is slower with thicker oils, when I used 10w40 engine oil it was slightly harder action and slightly slower return speed.
