Flat spot
Discussion in 'EFI/carb' started by Davidmark, May 3, 2017.
  1. Davidmark Husqvarna
    2009 te450
    2011 Ducati hyper 796
    Hey guys my 09 te450 has a flat spot when accelerate off of idle since I mounted the jd mod with the standard settings anyone had same problem and or a remedy?
  2. Slider Husqvarna
    Perth W.A.
    TE510 2009
    Kawasaki ZX12R 2003
    No air leaks, all sensors and CO/ TPS settings good ?
    Tried adding some fuel down low ?
  3. Tetley Husqvarna
    UK
    Could be a sign the injector filter is getting blocked? Only takes a very tiny amount of dirt to block this. It gets in every time the fuel hose is disconnected from the tank and reconnected again.
    See my thread on this from a few years back.
  4. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    Took my bike up to Mammoth @8000 ft plus. Had a bog off idle. Reset TPS and back in business.
    2012 TE 310 w/TXC ECU and 12 pt. Injector. Adjusting CO was not productive until TPS reset. Will ride later and add any experience or changes. Set at 105, 103, 100 I think. Also upped idle to just under 2000
    ETA I also brought my VW buggy up here with a new 1600 engine.. Solex/Baroso Carb. Ran like crap. Local guy Mike (Alpine Garage..has a Meyers Manx ) adjusted timing (advanced) adjusted carb and cleaned plugs and it runs fine now.
