Flat Tire Advice for 630 SMS
Discussion in '610/630' started by rocko, Jul 21, 2011.
  1. rocko Husqvarna
    San Diego
    630 SMS
    SV650
    So yesterday I had the pleasure of getting my second flat tire in 10 years of riding :mad:
    A screw punctured the tire (and I'm guessing there's a tube in there too). I called the dealer, they said they don't really patch tires (which is a bummer because it only had about 400 miles on it). They also said they usually put a 160 on the rear instead of a 150.
    I don't really like the idea of putting a wider tire on because then I imagine there might be clearance issues with the chain etc not to mention won't handle as well as with the stock tire.
    Have any of you switched to a 160? Was the difference noticeable?
    I looked around online and am having trouble finding a 150 width tire.
  2. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    I prefer the 150 on a narrow rim (sub 5"). Better profile but 160 will work. If yer running a tube change the tube and patch it from the inside. It it's tubeless you can plug/patch it from the inside with a patch that has a long plug thingy on the end you pull through the hole and snip off, the patch seals from the inside and the plug thingy plugs the hole. Had good luck with those on street tires, kinda messy but they work.
    Most dealers wont patch a street tire due to liability issues.
    Never try it on a sidewall. Chuck the hoop and buy a new one.
    Flats on the road SUCK. Carry a tubeless plug type repair kit if yer tubeless it'll get ya home in most cases if ya go slow.
    Get some Pilot Powers- they make a 150.
  3. Ketek Husqvarna
    Germany
    They're not tubeless. Just put a new tube in there and off you go :thumbsup:
  4. BadMotoWeazal Husqvarna
    Alabama
    Yep new tube & you're good... If you want to patch tre tire it yourself, it not hard or expensive, but it's not realy necessary. Stick with the 150 if you like the bike to turn in a speed a little easier. 160 looks good. but the wider tire is harder to turn in. G/L
  5. rocko Husqvarna
    San Diego
    630 SMS
    SV650
    Man I love these tube things....Nice to pay $40 bucks to replace the tube instead of $200 to replace the tire!:D
  6. LawnDartMike Husqvarna
    Salem, OR USA
    Is breaking the bead as hard as normal tubeless tires?
  7. rocko Husqvarna
    San Diego
    630 SMS
    SV650
    Don't know...I had the dealer do it but my guess is that it is.
