125-200cc Float height??
Discussion in '2 Stroke' started by Philmooo, Mar 25, 2013.
  1. Philmooo Husqvarna
    WR 144
    KTM 450 EXC
    What is the proper float height for the stock mikuni TMX 38 for the WR 144?
    Or what is the proper adjustment method? The carb was leaking fuel if leaned any farther than side stand angle. I adjusted the needle valve & float tang a bit but I am not sure it is where it needs to be.
    Thanks
  2. Philmooo Husqvarna
    WR 144
    KTM 450 EXC
    Oops I just found a bunch of post regarding this very issue. Sorry
  3. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    only advice i got is when checking the level hold the carby is at a 45* angle or so...so it dont compress the needle spring when getting a reading, ya want it to juuust touch the seat. least that's what gramps told me. isolate the tang when tweaking. dont use the float lobes as leverage. you can do eeeeeet!
