Float needle and seat size for a 2007 TE250?
Discussion in 'EFI/carb' started by millenium7, Apr 1, 2024.
  1. millenium7 Husqvarna
    2009 TE510
    Stripped the carb down and cleaned it all out, only to then discover its slowly leaking fuel out the vent lines when parked. I did notice the float valve looked slightly worn but didn't bother to check for any stamped numbers on the float seat
    Does anyone know what its supposed to be? And I can then order and wait for the parts without stripping the carb again
    edit: It's a keihin FCR carb. Presumably the FCR MX 37 but unsure if these all have the same size float valve/seat, there's quite a few different keihin FCR seat part numbers/sizes
  2. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
