Floating rear disk
Discussion in '4 Stroke' started by aethelred, Feb 27, 2010.
  1. aethelred Husqvarna
    UK
    What is the floating rear disk all about? Other makes use the same Brembo kit but the disk is solid. Mine makes one hell of a racket...
  2. Muddy Waters Husqvarna
    On the islands
  3. kleemann Husqvarna
    Colorado
    A floating disc can take huge heat cycles and not warp. If you take measures to try and solidify the disc to the hub you will largely negate its functionality. I doubt seriously you can hear it while riding?
  4. fury1 Husqvarna
    ma.
    you can hear it once it gets a bit loose,but i have never boiled the fluid
  5. Up-tite Husqvarna
    Loosen the mounting bolts and rotate the mounting bushings they just get worn and alow the disc to rattle more. Later George
  6. CARL REHATCHEK Husqvarna
    Tamaqua, Pa
    2010 TE 250
    Hear it while adjusting and lubing the chain but not while riding or racing.. Thanks for the tip George as time wears on..
    Chow, Carl
  7. Wadman Husqvarna
    south carolina
    As long as I can hear mine rattling I know it hasnt fallen off.
  8. aethelred Husqvarna
    UK
    True enough...:)
