Floating Rear Rotor?
Discussion in '4 Stroke' started by mtne, Nov 14, 2009.
  1. mtne Husqvarna
    Denver
    08' TE610 + 08'TE610 sumo'd
    KTM 950SE
    Anyone know the why of Husqvarnas use of a floating rear rotor?
    Any reason to not use a fixed one?
  2. ghte Husqvarna
    Bright, Victoria Australia
    The floating disc is to assist the brakes in wet greasy conditions where mud etc. may attatch to the discs/pads and cause premature wear. The floating aspects adjusts better to lumps of goop. Only downside is they can at times rattle when at idle.
  3. Muddy Waters Husqvarna
    On the islands
    Or at the back of the van when your driving…..at lest until you sand the wife to the back to put a rug on it :busted:
    :thumbsup:
  4. mtne Husqvarna
    Denver
    KTM 950SE
    Ok, good. I've swapped out the woodys cush hub off of my KTM to the husky and it's has a hard mount rotor. I figured to keep the nice wheel rather than sell it with the KTM for not much price gain. All it took was a bearing swap to match the husky axle and turn a couple of spacers......
  5. PALMER84ONE Husqvarna
    Silverado, CA.
    08 TE450 THE ROCKET
    12 RS520, CRF150F/230F, YZ250
    Another benefit is a cooler running rotor and pads. Never to boil your fluid and have brake fade. But not a must .
  6. Bones Husqvarna
    Cedar Rapids, IA
    Thanks for pointing me to this thread. I think I am going to run a fixed since I have it, unsure which wheel I will run it on. The 18" dirt wheel or 17" street wheel? Thoughts?
  7. Yossarian Husqvarna
    the 'Ha
    2008 TE610
    Multistrada 1200 Enduro; Tiger 800XC
    I think you would be using the rear brake a whole lot less when riding on the street, so I'd mount the floater up to the 18" dirt wheel and the fixed to the 17" street wheel.
  8. Motosportz CH Sponsor
    It is also harder to bend a floating rotor as it has some give. :thumbsup:
  9. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    It's not the rattle of the floating disc that gets me... it's the spark arrestor insert. Sounds like there're marbles in there.
  10. Bones Husqvarna
    Cedar Rapids, IA
    That was my thinking also. I won't be pitching the rear like a good ride could. :lol:
    I guess I can see that logic also.
    Time to make a caliper adapter for my 320mm front over the winter and I am set up! Thanks
  11. andyman Husqvarna
    I was riding around in on the "lawn" today just practicing slow speed maneuvers and such. I kept hearing this crazy rattling sound. It didn't take long to figure out it was the floating rear rotor. Today was the first time I ever heard it, and I was wondering if it was normal. Thanks to those who have posted about it rattling here. Saved me some worry. :cheers:
    (I suppose I've never heard it before, b/c I 've previously always had the spark arrester in place... the rattle of which nearly drowns out the motor.)
  12. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    I was told the SA rattles to keep it from being stuck by the carbon deposits that settle on it....so I didn't even try and "fix" it. It's a "feature"....;)
  13. Poopy Husqvarna
    Kamloops, BC
    WB165
    Strange, I too was putting around in my yard today and noticed it rattling around for the first time.....:excuseme:
  14. Tighttwisties Husqvarna
    Washington State
    I took the sparky out and applied some hi-temp silicone to the thick round (solid) metal part that fits tight to the walls of the opening. Reinstalled it and the clip ring. Wiped off the goober and let it dry overnight. No more sparky rattle but the disk drives me nuts.
  15. Motosportz CH Sponsor
    You can also slighty bend the clip and reinsert. :thumbsup:
    As for the rotor i have seen people use small o-rings around the mounting tabs and then around the disk where it meets the tabs. Overkill for me as i don't care if it rattles or not. :D
  16. xymotic Husqvarna
    Federal Way, WA
    If it's REALLY bad I'll touch the brake. PADS ARE CHEAP :)
  17. fitness2go Husqvarna
    Seattle WA
    I agree. What the hell are you all focusing on out there on the trails? I have never once noticed anything but what's in front of me. Thanks, I'll probably notice it now and it will bother me. :banghead:
  18. Picklito Husqvarna
    Washington
    Hmmm. That's probably true. Whether they intended it or not!
  19. xymotic Husqvarna
    Federal Way, WA
    Ha, well I will say it VERY RARELY bothers me. I only hear it at slow speed on pavement and well usually if I'm going slow I'm braking really hard:lol:
  20. fury1 Husqvarna
    ma.
    I only hear it pushing my bike or idling or now riding behind my old bike!
