250-500cc Flywheel Puller 09 Wr 300
Discussion in '2 Stroke' started by Rob578, Feb 12, 2012.
  1. Rob578 Husqvarna
    Atlanta GA was CA
    Beta 300RR Beta 500RS TE 630
    Honda 919 sold FJR1300 sold
    Anyone know what size? Is it 22x1.5 RHT?
    Thanks
  2. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    I'll check mine out and get back.
  3. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    That is the correct size.
  4. Rob578 Husqvarna
    Atlanta GA was CA
    Thanks now I have find one of the oddball things
  5. R_Little Husqvarna
    NJ
    When you do it make sure the puller bottoms against the flywheel before it runs out of thread.
    My puller did not and just tightened until it stripped the pulller threads. I was like how tight is this flywheel?????!!??
    I had to add a washer under it and the Fywheel came right off.
    just an FYI.
  6. Rob578 Husqvarna
    Atlanta GA was CA
    Got the puller from Halls, used a 1/2 air impact and it came right off
  7. TROFFER88 Husqvarna
    Camas Wa
    I just got a 6 speed to do a swap, I would like to here what you think when you get yours done
  8. Xcuvator Husqvarna
    Scholls Oregon
    yes
    The first impression of mine after riding it up and down the driveway was that the ratios were about the same with a 6th gear added. After actually riding it, first and second are lower and all the gears are nicely spaced.
    Maybe you've read this but here is some more reading on it from back when Walt first did one:
    http://www.thumpertalk.com/topic/532293-wr-250-5-speed-to-6-speed-swap/
  9. TROFFER88 Husqvarna
    Camas Wa
    What gearing are you running Steve ?
  10. Xcuvator Husqvarna
    Scholls Oregon
    yes
    14 50 I don't think I would need to go any lower for anything. But I haven't rode it on the wetside yet. Should be good though.
    Could stand to be a touch higher for the Eastside, but compared to the 5speed, it seems like it really flies now.
