Flywheel Puller Sizes
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Phoenix, May 9, 2012.
  1. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    2 Ducs, 14 GG 200, 13 Husa 300
    I was having trouble finding the X-Lite puller size, so I thought I'd post this info now that I have found it.
    X-Lite 250/310 Engines 26mm x 1.5 RH Female Thread
    Previous gen 450/510 Engines - 26mm x 1.0 RH Female Thread
    2009 & 201010 TE310's - 28mm x 1.0 RH Female Thread
    2 stroke - 26mm x 1.5 RH Male Thread
    These are available in the Parts Unlimited Offroad Catalog from Dennis Stubbefield. I'll report back on quality when they come in, but they look comparable to Motion Pro, etc.
  2. JasonfromMN Husqvarna
    MN
    None right now :(
    2013 Yamaha FZ6R
    Excellent. How much was it? I can't see the price.
    Oh and why are you pulling your flywheel?
  3. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    Both pullers were about $19.50 from powersportsjunkie.com.
    The 450 flywheel was being pulled to do a top end and cam chain replacement. I'll also have to use it to find out why my old KTM sounds like a John Deere tractor.
    I bought the 250 puller just to have one around. I ran across a thread that mentioned the woodruff key and flywheel could be of issue with hot starting problems. I'd like to check it after those top two projects are settled.
  4. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    nice! tahnks for sharing...
    is the ktm an RFS? check the right side crank nut (reverse thread aluminum nut- and woodruff key should be replaced if it loosend, and reinstal with Red Locktight to spec torqe.
    Does the Ktm RFS use the same as the Husky 450? if so I have one== sweet! I won't need to buy another when the time comes!
  5. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    Yes, KTM RFS is the same for sure. As far as I can tell from internet research, it looks like virtually all KTM four strokes from at least RFS to present use the same puller. My KTM is a 2007 250 XCF-W RC4 engine, and sites like Rocky Mountain show the same puller for this bike. I'll look and see if my engine has that same nut/key setup and check it. I fear that it may be a crank bearing or something of that nature.
  6. RailwayRog Husqvarna
    I bought the Motion Pro 26 x 1.0 R.H. puller for my 2011 te310 but the threads on the flywheel look coarser.
    Can anyone verify the threads on the flywheel?
    I can't thread on the puller.
    Ahh I should have paid more attention, I should have went with the 250 X-lite engine, forgot most components are the same, Duh
  7. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    I'm so sorry. :( I wish I had put 310 as well. I edited the original post so hopefully nobody else will get caught in my trap. :(
  8. JasonfromMN Husqvarna
    MN
    None right now :(
    2013 Yamaha FZ6R
    Phoenix, is your flywheel teeth that the worm drive connects with have a slight concave groove in the middle? I had mine apart tonight to reseal the cover where the wires come through for weeping oil. I had a look around and noticed the these grooves. They did look factory but I just thought I'd ask. Mine does start perfectly though.
  9. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    Yes, it looks just like that. I thought it was wear when I first looked at it.
  10. Paul B Husqvarna
    Australia
    2099 TE310 with SHOWA forks
    Hi all I have an 09 te310 and just bought a 26mm x 1.0 and it doesn't fit. Seems that the flywheel is 27 or maybee 28mm can anyone tell me if they have come across this and what size puller that I need?
    ****EDIT****
    09 & 10 TE310's are 28mm x 1.0 RH female puller.
  11. myneddmonster Husqvarna
    South Wales
    Was TE310 now '14 Husqvarna FE 350
    Triumph Tiger Cub project bike
    My 2012 TE 310 is M26 X1.5 RH Female.
    Did not need it this time, though.
    The Woodruff key had sheared off and the flywheel was spinning free.
  12. Kenneth Webb Livin' It Up!
    Tucson AZ
    TE630 TR650 Terra TE310R
    Shearing the Woodruff key seems to be a semi-regular thing with the X-Lite. Maybe we should all take the time to lap the taper to make sure that we have a good fit. My bike is in the shop now and I think I'll ask the mechanic to do this before buttoning things up.
  13. banana944 Husqvarna
    Central MA
    2009 SMR510, 1996 WXC360
    01 YZ300,01 KDX200 both street legal
    Can anyoen confirm the flywheel puller size for the 08-10 450/510? I got an M26x1 and seems to small. Assuming it would be the M28 puller but hoping someone can confirm.
  14. Teeszy Husqvarna
    Crescent City, California
    2006 SM510R , 2016 FE501S
    the 26 fits the 06' but the 2008 510 needs a
    M28 X 1.0 R.H.
    It was hard for me to figure out so hopefully I can help others figure it out with less effort than i did.
    fyi, removal of my flywheel was one of the hardest things I've ever thought would be easy. lol it's not complicated but mine was really stuck on there
  15. banana944 Husqvarna
    Central MA
    Thanks Teeszy. I have one on order already. I pretty much confirmed for myself by looking in the micro fiche. This thread lists the 310 as having and M28x1, and it shares the same flywheel as the 450/510.
    Good information to have out here though!
  16. banana944 Husqvarna
    Central MA
    So I am going crazy. The M28 puller is too large for my flywheel!
    So The M28 is correct for a 2009 SMR510. The first one I got was sold as M28 but was larger... go figure.
  17. Wheel1 Husqvarna
    OHIO
    1988 TE 510
    Ive looked all through Most of the posts about Flywheel puller .
    I have a 1987/1988 TE 510 that has the reverse flywheel w Rh female threads & the stator mounts on the outside case.
    I purchased a 26mm like suggested in several posts , Not Close
    Any suggestions ? 1987/1988 TE 510 Reverse Flywheel set up .
    Thanks in Advance for all information.
  18. monak83 Husqvarna
    TE 310 2011
    I have a TE310 2011 and I have taken 28x1 but is too big.
    What I need? 26x1 or 26x1.5?
    Tanks a lot
    Regards
    Marco
