250-500cc Flywheel removal tool. Which one?
Discussion in '2 Stroke' started by Husky Gordon, Mar 22, 2014.
  1. Husky Gordon Husqvarna
    WR 300
    KLX 400r
    What size flywheel removal tool do I need for a 2009 WR 300. Everything I see call for. 22mm but it is smaller than a 19mm.
  2. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
  3. Husky Gordon Husqvarna
    WR 300
    KLX 400r
    The nut that holds the flywheel on takes a 19mm socket to remove. The hole in the flywheel is smaller than the nut. The nut has a long shoulder that goes back into the flywheel. That's why I said 17mm. But everything and everyone is saying 22mm. Why is mine different? Coild it e a flywheel from something else?
  4. uranys Husqvarna
    Pittsburgh, Pa
    96 xr600r
    There are threads on the inside of the hole that are 22x1.5
  5. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    have you got any pictures? some one could of put another ignition on but unlikly considering the age of the model in question.
    i was going to put 22 but you stated its smaller.
  6. Husky Gordon Husqvarna
    WR 300
    KLX 400r
    Thanks, I will order one and give it a try.
