FMF Turbine Core II on a 1982
Discussion in 'Vintage/Left Kickers' started by 1982 XC 430, Mar 24, 2011.
  1. 1982 XC 430 Husqvarna
    Seattle Wa
    Today I installed a FMF Muffler on my 82 250 XC. I used the FMF Universal Kit and it took about an Hour start to finish. They make a 1 1/8" and 1 1/4" size Your going to want the larger one for 250's and 430's and 500's. The Tube leading into the Muffler is the same size as the Tailpipe on the Stock 250 Exhaust. I had a Scrap Tube that would slip over both of them so I Tig Welded it to the Muffler and put a couple of Tangs on it for the Stock Springs. A section of High Heat Hose like all the New Bikes have would do the same thing. The Slideing Mount the Kit comes with needed a new Hole Drilled to line up with the Stock Aluminum Frame Mount. Its got a USFS Spark Arestor I havn't started it yet but I doub't it will be much louder than stock.
  2. Norman Foley Husqvarna
    Great info. A friend need s a new silencer for his '82 430XC.
  3. Husq.fleet Husqvarna
    Pendleton Oregon
    I have one on my 84 WR250 and it works great!
  4. NFG Husqvarna
    Post up some pic's so we can see what it looks like. I have an 81 430 XC that will be needing a new tailpipe. This may sway me....
  5. Skidmark Husqvarna
    Big Island Hawaii
    I would LOVE to see your pipe set-up! I have a FMF Q-Stealth on my RM250 and it is VERY quiet....great for sneaking around in the woods. I'd absolutely love to put one on my 82 WR 430.
  6. adam6402 Husqvarna
    Tulsa, OK
    None
    I found that the adapter that comes with the Universal Tubine Core II along with the end of the stock tailpipe just needed a little cleanup and they would slide very tightly together. On the pipe, there was a slight ridge on the inside diameter that I smoothed down with a dremel. The adapter per my digital calipers measured about 1.255". I used a small grinder to skim .005 off of the adapter to take the diameter down to about 1.25" and the result was a nice very tight strong fit.
  7. Husq.fleet Husqvarna
    Pendleton Oregon
    Here is a pic. Pardon the mud and spooge as its a rider!
  8. Husq.fleet Husqvarna
    Pendleton Oregon
    Another shot, its a 84 WR250
