nev..
Terrarist
I have to credit HF for the photos here. He posted these on ADVrider and I washed my filter before I took any photos so I have used his as example because mine was identical.
This is the filter out of the Terra. The dirty side is away from the filter cover, the clean side is towards the filter cover. Due to the air coming in from the angle, only half of the filter is in the stream of air and gets dirty.
So here is my question. Say I was away from home and had no means to clean the filter, and it was getting quite dirty on the side in the direct airstream, but still mostly clean on the other side...
Should I put the filter back in the same way. The air rushing in will hit the dirty side, not so much of it will get forced through that side of the filter and over time less and less, but the other side of the filter is unobstructed allowing clean air through, but it is not forced through by the airflow ..
or
turn the filter around, face the clean side into the direct airflow, so that I am getting more clean air forced through, but as the time progresses, I will eventually have both sides of the filter obstructed dirty and obstructing airflow..
opinions ?
or
opinions ?
