folding clutch lever
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Jack Trotter, Oct 12, 2015.
  1. Jack Trotter Husqvarna
    Inland Empire
    2015 Husky FE 350S
    KTM 300 XC-W
    My bike is a 2015 Husqvarna FE 350S. I tried to install the Husqvarna folding clutch lever, but it won't work. The folding lever hits the turn signal/horn housing unit, so the lever won't engage enough. If I move the lever closer to the housing unit the lever adjustment knob hits the housing unit. The stock lever hits the housing unit, but engages enough. It's almost like the folding lever itself needs to be configured differently so it does not hit housing unit. Anyway, anyone know of a folding clutch lever that will fit the 2015 Husqvarna FE 350S? Hoping to find a blue to match my brake lever!
    This is an awesome site. I will use it often. This is my first Husky since 1986!
  2. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    Im using ARC Memlon, but my crew member is using the OEM catalog blue folding levers on his FE350S. Mine fit my TE300 without issue and his FE350S installed powerparts levers have been on for a while now. I think you just need to make some position adjustments.
  3. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    Sounds like you either need to reposition throttle housing or slide front brake master cylinder in or out a little
  4. Jack Trotter Husqvarna
    Inland Empire
    2015 Husky FE 350S
    KTM 300 XC-W
    Thanks for the repling guys. It seems like a simple adjustment, but it's got me puzzled. I'm going to try another brand of folding lever to see how it fits.
