Folding tip shifter
Discussion in 'TR650' started by rww, Feb 13, 2013.
  1. rww Husqvarna
    Kennewick Washington
    tr650
    Ducati, Cagiva Kaw Zuki Honda
    While cruising the web I cam upon a post where some one had ordered a moose racing folding tip shifter for a 2003 XR250R 2003 Honda and put it on a G650GS ,2007, and said it fit "perfect" . Does anyone have one to see if this is true ? If this is a yes, there will be choices out there for cheap.
  2. rww Husqvarna
    tr650
    Well the one from msr has the same splines and will go on but hits the case unless the tip is pretty low....SOooooo NO go ....buy the Touratach piece
  3. kjackbrown Keep on keepin on.
    Fresno, Ca.
    KLR650
    Thnx for trying!
  4. Xch Husqvarna
    Australia
    None yet
    Honda
    http://www.advrider.com/forums/showpost.php?p=6920187&postcount=3196
    Quote:
    Originally Posted by Skaife
    I checked out the sticky thread and read that the F650 Dakar lever will work. Does the year matter?
    Also read that the steel Moose lever for an XR650 MIGHT work. Can anyone confirm this does anyone have a part number for a lever they know works?
    Quote:
    These may work as they fit the BMW.
    1) A 99-06 MSR YZ250 shift lever will fit perfectly (PN 34-2148),
    or
    if you want a shorter shift lever then use
    2) A YZF and WRF (250, 426, 450, 400,etc) (PN 34-2147)
    The above shifters will bolt right on..The splines are identical, and the bends are perfect..
    Moose shifter.
    Part# 1602-0015. bought it from Thumper Talk Store for $30. It shows:
    YZ250F (06-08)
    YZ 450 (06-08)
    WR250F (03-08)
    WR450F (03-08)
    It is a steel shifter w/folding tip.
    Also look here for other ones.
    http://www.advrider.com/forums/showthread.php?t=335086
  5. rww Husqvarna
    tr650
    How much shorter is the YZF/WRF lever ??
  6. Toyboy Husqvarna
    Middletown, PA
    2011 TXC250/2012 TXC310, 2013 TR650
    BMW Hp2E/Yamaha Super T/BMW R1200RTP
    MSR folding tip shifter for the YZ250. Part number 34-2148 25.00 retail
    FabOneUp and nev.. like this.
  7. Hansi Husqvarna
    State of Jefferson
    TR 650
    09 Versys
  8. Toyboy Husqvarna
    Middletown, PA
    YZ250 05-2012
  9. Kenneth Webb Livin' It Up!
    Tucson AZ
    TE630 TR650 Terra TE310R
    I have the Touratech shifter and it fits, but there was only ONE position that worked. Down one spline and my boot wouldn't fit under the tip. Up one spline and the shifter hits the case. However, in the workable position, the lever is just fine for my size 10 boots. If you have really big clodhoppers, you'll just have to experiment.
  10. Toyboy Husqvarna
    Middletown, PA
    This one did give me at least 2 to 3 positions without rubbing case, more in the higher than lower position. Down side is it is gorged alloy which I found will not bend back far if tweaked. I thought about bending it in but not going to at this point.
  11. rww Husqvarna
    tr650
    So will it get level with the stock pegs ???? or at least the same position.
  12. kjackbrown Keep on keepin on.
    Fresno, Ca.
    KLR650
    I always liked these...
  13. Toyboy Husqvarna
    Middletown, PA
    Yes it will
  14. TerraNick Husqvarna
    Terra 650
    None
    I busted my stock lever on one of my first rides(hiding rock in the tall grass)... I was out of luck because the husky/bmw dealer was closed for the day, but a japanese motorcycle store was open, so I picked up a shifter from an xr650. It stuck out further than the stock for sure, but the splines were the same, the bolt to tighten it down was a little hard to access once on the bike though. For a quick fix, it worked, but once the touratech lever came around I bought it. Not the adjustable one, just the folding tip version. Very clean looks, in a light crash it would survive. they drill the steel out so in a bad crash it will break the lever, not the selector pin. Good idea in my book. Ill carry the xr650 lever with me just in case.
  15. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    They look good...but do they fit??? :thinking:
  16. kjackbrown Keep on keepin on.
    Fresno, Ca.
    KLR650
    They do offer the YZ shifter....just need to figure out what other break pedals are compatible.
  17. Toyboy Husqvarna
    Middletown, PA
    Wicked good looking pedals!
    The only brake pedal close enough to work with a mod or 2 is the one for the F800GS, that I found. It was steel and I had to cut and weld. Biggest difference is the rear portion of the pedal has too shallow an offset to actuate the master so I cut it off teh original pedal and grafted it onto the new pedal. These are all steel so welding not an issue.
  18. kjackbrown Keep on keepin on.
    Fresno, Ca.
    KLR650
    Could you do me a favor and post a pic please? I want to use it to (visually) cross reference other shifters.
  19. msmith345 Husqvarna
    Shawnee, KS
    '12 WR250, '92 360, '80 390
    '72 Yamaha R5, '17 SV650
    About the Torc 1 shifters, the toe piece for the YZ models are blue, so if you want the red it's another $10 to get the red replacement.
    I had a deal with them, so I ran all their stuff on my KTM. It was good stuff, but the foot pegs had a design issue with a KTM 200 kick starter. Easy fix though.
    The adonizing doesn't last long. At least on the shift tip. It's hard to say if it's from the boot or from the conditions I race in. It might last a while on the road. I'll probably order one in a couple weeks.
  20. danielcure Husqvarna
    Vancouver, BC, Canada
    Terra 650
    CR500. CR250, CBR400, CBR600RR, VTR1
    Hi TB
    I was about to purchase this but noticed that you mentioned the year was YZ250 05-2012 but the part number brings up the below: is this the correct pedal?
    MSR Forged Aluminum Shift Lever Yamaha YZ250 99-04 34-2148
