250-500cc Fork Bleeders - Threads?
Discussion in '2 Stroke' started by Jhunter, May 1, 2013.
  1. Jhunter Husqvarna
    Atlanta
    I was doing a quick search on Rocky Mtn ATV and I see two or three 'push button' fork air bleeders. Most all say 5x0.8 threads. Will these work on the Zokes?
  2. Jhunter Husqvarna
    Atlanta
    Anyone know?
  3. lankydoug Husqvarna
    MO
    WR
    TM 300en
    I bought my Zoke bleeders from Motosports, if I remember correctly they were priced better than most other internet sources.
  4. 72racerx Husqvarna
    Melbourne, Australia
    13 WR144
    01 VFR800
    From memory the Zook forks have the same thread size as WP forks
  5. Max Payne Husqvarna
    Medford Oregon
    6 of them
    6 of them
    I just put Motion Pro bleeders on my single chamber 50mm Marzocchi Shiver forks and 4x0.7 is the correct size. It is a tight fit because the hole is so close to the raised hex on the cap, but they do fit.
  6. huskybear Husqvarna
    B.C. Canada
    Yes, they are the same thread:thumbsup:
  7. robertk61 Husqvarna
    09 WR250
    Yep I can confirm that too.
  8. Jhunter Husqvarna
    Atlanta
    OK, I'm going to order the 4x.07 bleeders. I'll report back once installed.
  9. street2dirt Husqvarna
    World's Most Famous Beach
    12 TXC310, WR300, 85 125WR, 82 175XC
    BMW G650X
    Most suspension tuners that I've talked to recommend to NOT use these. Some say they will actually suck air into the forks. Just a little info, do your research.
    Dunlop likes this.
  10. Jhunter Husqvarna
    Atlanta
    I called MotionPro today to figure out what bleeders would work. They didn't have much info on the Zokes. Looks like I'll need to pull the screws out and do some measuring. I'll post again once I have this thing nailed down to a part number...
  11. huskybear Husqvarna
    B.C. Canada
    I bought fork bleeders for my husaberg (48mm white power) and they fit my husky forks perfectly(50mm 'zokes,2010 wr150). Sorry,can't remember the part #.Hope this helps:cheers:
  12. motosportz mike CH Sponsor
    Washington state
    It will actually depend on which bike (or fork) you have. Marzocchi forks use different bleeders for different models. This is why you are getting different answers.
  13. Jhunter Husqvarna
    Atlanta
    Correct, Per the guy at MotionPro, the 45mm and the 50mm have different thread sizes or depth ect...
  14. Max Payne Husqvarna
    Medford Oregon
    6 of them
    6 of them
    I don't see any mention in this thread mentioning what forks you actually have... 45mm or 50mm, open chamber or closed chamber? As I mentioned before, the Motion Pro 4mm x 0.7 are a direct fit on the 50mm open chamber. I have first hand knowledge of this. Sorry I can't help with other models.
  15. Jhunter Husqvarna
    Atlanta
    I ordered some MotionPro bleeders from RockyMtnATV. They were 4x.07 and I made sure they fit the WP forks. I think the only issue will be how close the screw hole is to the top of the hex cap. Here's a photo of my top cap.
  16. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    They will fit no problem :thumbsup:
  17. Jhunter Husqvarna
    Atlanta
    Mission Complete. I bought the 'MotionPro' Micro Bleeders from RockyMountainATV. I have a 2008 WR-250 with the 45mm Zokes (the bleeder screw thread is 4x.07). The RockyMtn part number is #135995001 and MotionPro #11-0080 (Black). If you go by application, I used 2004 Husaberg FC450. The key is 'black' version because it gives you enought room to clear the hex cap. Quick and easy 5 minute job and only $12.99 :D
    454x likes this.
  18. Flynny Husqvarna
    Cambridge (uk)
    WR 250 2004
    They look awsome ....! Much easier that pulling the screw. Will they fit my wr250 2004 that has zokes on it but I'm not sure what type. The screw is pretty small.
