fork rebound damping question
Discussion in 'Vintage/Left Kickers' started by stainlesscycle1, Dec 6, 2010.
  1. stainlesscycle1 Husqvarna
    morgantown, wv
    one of my 35mm forks has very little rebound damping. when i take the springs out it has resistance both ways, although a little light compared to the other fork.
    these are 1979 390 auto husqvarna forks.
    i'm assuming a seal on the damping rod is bad - i haven't taken it apart yet. the fiche just shows part 25 (15 12 258-01) - is this a seal or plastic washer? is that all there is at the bottom of the damping rod - i guess i'm just asking which parts i should order to freshen up the damping rod..
  2. stainlesscycle1 Husqvarna
    morgantown, wv
    took it apart. broken damper rod plastic sealing band. i'm assuming it's part #151225801
    now to find a pair to fix it..might as well replace the one in the other fork too..
  3. oldhuskychuck Husqvarna
    Denver Co
    i have a complete set of used 79 forks that id sell. contact me if you like.
  4. stainlesscycle1 Husqvarna
    morgantown, wv
    no need, i have 4 sets of these forks already... ordered replacement parts for dirt cheap..
