Fork seal Hak
Discussion in 'TR650' started by Bluff Boitjie, Nov 18, 2024.
  1. Bluff Boitjie Husqvarna
    Durban, South Africa
    Terra 650
    I'm based in Durban South Africa and spares are non existent here. I used a 46x58x9.5 fork seal. It is 1 mm thicker than than OEM seal. I had to carefully machine off 1mm on the back side, the side that sits against the forkleg. 9.5 to 8.5
    The fork tube itself can't be machined to take a thicker (9.5) seal as it makes the area where the fork seal sits too weak. When I measured it all up, there was only 2mm of "meat" there, so machining that would make damaging the fork too risky. Put the original dust covers back and Bob's your uncle!
    mysery1 and Dirtdame like this.
  2. sussurf Husqvarna
    Port Macquarie area, NSW
    Triumph Sprint 1050, Daytona 955i
    So you machine the face of the fork seal that has the text stamped on it?
  3. Ghostman Husqvarna
    Portugal
    TE 450
    Brutale 990, Vespa GT200
    Do you need the original fork seals?
