Fork spring cup in 2009 txc 450 forks, 50mm marzocchis. Technical question
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by 4banger, Feb 9, 2014.
  1. 4banger Husqvarna
    2009 TXC 450
    I took apart my 50mm forks on my 2009 450 txc and had a technical question that I could not find in the manual or online.
    The spring cup(#13) is basically a washer with a seat or groove on one side. The manual doesn't say which way to put it on. I am second owner of the bike and the previous owner had serviced the forks. And when I took the forks apart, one spring cup was facing up on one fork and the other one was down on the other fork so I dont know the proper facing of the part.
    Just need to know if the indent is up or down. Thanks in advance,
    mark
  2. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    EDIT: See comments from other members below. Apparently I was thinking of a different washer than the question was asked about.
  3. 4banger Husqvarna
    2009 TXC 450
    I appreciate the response. I put them back together. I scoured the internet for information and nothing. The washer fits between the fork seal and the upper bushing. I don't think it will harm anything either way put in but there should be a right way. Ill try to call marzocchi and see what they say. couldn't find an email for them either.
  4. Xcuvator Husqvarna
    Scholls Oregon
    yes
    I'm pretty sure Zipty can answer your question.
  5. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    The stepped side goes towards the seal and is supposed to help keep the seal centered. The seal can float and leak if it is installed the other way.
    Later,
  6. 4banger Husqvarna
    2009 TXC 450
    Thats how I put it in. the flat side toward the bottom guide bushing and the cupped side toward the fork seal.
    I appreciate the response. I changed the oil to 5wt at 280cc and did the refill/air purge on the closed chamber. Hopefully will be better. thanks,d
    mark
