125-200cc Fork upgrade question
Discussion in '2 Stroke' started by johnhuskywaine, Sep 29, 2014.
  1. johnhuskywaine Husqvarna
    Cr 125 1998
    Next on the list of upgrades for my 1998 cr125 are the forks, I've sourced some upside down standard forks of a 2004 model, does anyone know if these will fit str8 on or do I have to change the front wheel as well or anything else??
  2. WVdag Husqvarna
    Smithville, West Virginia
    2007 WR250 W/300 kit, 2013 CR125
    1987 Harley FXLR 10th year edition
    Hey, I have a set of inverted 45mm Zokes , triples and all off of a 99/2000 cr125 if you are interested. I bought them for a project that never materialized.
    Dave
  3. johnhuskywaine Husqvarna
    Cr 125 1998
    id be interested if it was in the uk? :)
    do u know if you have to change front wheel? axle? brakes?
  4. johnhuskywaine Husqvarna
    Cr 125 1998
    Anyone else?
  5. WVdag Husqvarna
    S
  6. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    98 an 99 are almost identical
    98 has conventional forks on the WR models and the decals are a different color
  7. 2premo Husqvarna
    Northern NV
    o
    they can fit but you need to do a couple things, if you want to use your front wheel change the bearings as the axle in the 2004 is fatter, trying to remember what was different about the brakes an if memory serves the caliper adaptor is fork specific so you need a caliper mount and wheel bearing and if the forks did not have an axle you will need that too
    on the bearings you need the spacers too
  8. johnhuskywaine Husqvarna
    Cr 125 1998
    thanks premo, im going to try and get the front wheel with the forks so hopefully ill just need a calliper adaptor at most!!!
    being a 1998 cr that's gonna trake me months to find :banghead:
  9. 2premo Husqvarna
    Northern NV
    if you have the same brand forks your adaptor should work
    does you 98 have inverted Zokes :confused:
  10. rancher1 Husqvarna
    WA
    I believe the caliper should bolt up from the 98 to 2004.
