250-500cc Forks 2009 husqvarna wr300
Discussion in '2 Stroke' started by billyp10980, Oct 28, 2013.
  1. billyp10980 Husqvarna
    New York
    Does anyone know what forks would fit a 2009 husqvarna wr300? Are there any other year and model Marzocchis that would fit?I have a damaged fork and have been shopping around for a replacement but I don't want to make a mistake and get something that doesn't fit. Thanks.
  2. fredd Husqvarna
    PUERTO RICO
    2016 kx 450f
    1995 chopper
    i dont know.:excuseme:
  3. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    good again fredd. anything 50mm would work id assume provided you can get the front wheel/axle/fork guards/caliper etc if not husky spec. if you wanna buy new triple clamps you could go 48s i spose, gettin expensive though!
    454x and fredd like this.
  4. billyp10980 Husqvarna
    New York
    There wouldn't be any other husky models that share the same setup as the wr300? I looked on Ebay and asked questions about other 50mm forks off other model husky's but nobody seems to know if it would fit my bike. So far I cant find any forks off any wr300's for sale.
  5. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
    My 09 TXC250 has 50mm Marzocchis.
  6. billyp10980 Husqvarna
    New York
    Do you know the part number on yours?
  7. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    The dual chambered 50mm Zokes from my 09' CR125 fit my 09' WR300 just fine. No fitment issues at all.
  8. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    most the husky front ends are the same bar maybe axles on the 250/300s im pretty sure-all oc kyb 48s the same 125/250/300/310/449/511 so id assume when they were running zoke 50s it was the same deal
  9. fredd Husqvarna
    PUERTO RICO
    2016 kx 450f
    1995 chopper
    im just trying to help thanks.:thumbsup:
  10. flyingbob Administrator
    USA
  11. flyingbob Administrator
    USA
  12. ajaxauto Husqvarna
    do you have 45mm,48,mm or 50mm I have a few sets of just about everything so let me know what size both zokes and KYBs
  13. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    if you use the triple clamps with them most all Husky front ends will work, you need to consider the axle if you go backwards too far
    I have a spare 04 front for my 99, it is a direct fit for the whole front and uses the same axle, Husky is pretty good about this
    hope this helps
  14. billyp10980 Husqvarna
    New York
    I have 50mm. Zokes
  15. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    Anything from 09 will work.
  16. ajaxauto Husqvarna
    I have a 2006 Wr 250 which had 45 zokes stock My 2010 WR 300 had 48 mm KYBs When I put the Ohliens on the 2010 bike I figured I would put the 48 mm KYBs on the 2006 bike Well EVERYthing I mean Everything was different
    I used a 48 mm triple clamp from a 2011 449 had to use both the top and the bottom clamp then the 449 does not use a steering stop on the clamp like the 06 bike did the stop is on the fram.then i had to change the stablizer mount because it would not fit the new 48 mm top clamp then the front caliper is different the 45 mm forks use a smaller caliper like a 125 after that had to change the ft axle spacer because of the offset so yes it can be done and yes it was worth it but make sure you get all the parts to make it happen
    Easy way would be to find just another 50mm
    which i thought i had and now i find out I only have 45 and 48mm forks
    Call Ty or Danny at Zip Ty Racing 760 244 7028
  17. billyp10980 Husqvarna
    New York
    I really appreciate the info. As soon as I get free I will call. Man, what a process! Lol!
  18. billyp10980 Husqvarna
    New York
    What does it mean when the fork tubes have nitrate coating? Does it work any better or protect the fork any better then just the stock look?
  19. Jubes Husqvarna
    sydney AUS
    wr300(09)
    Anyone know of any aftermarket fork trees that fit the 50mm treetrunks?
  20. Husky Gordon Husqvarna
    WR 300
    KLX 400r
    My 09 300 has either 45 or 48 zokes. I ordered new springs for the 50 and when I brought in the forks found out they were smaller. Seems like lots of parts can get changed around on the 300.
