250-500cc Forks too stiff
Discussion in '2 Stroke' started by Jhunter, Mar 29, 2015.
  1. Jhunter Husqvarna
    Atlanta
    I need a little advice. I bought a 2nd 2008 WR250 recently. The previous owner just replaced the fork seals. The compression feels stiff and I'm not getting enough travel. I'm not sure if I have a spring issue, too much oil issue or my compression is just set wrong.
    So I was thinking step 1 would be to back off the compression. Correct me if I'm wrong but this the adjustment on the top of the fork? The clickers on the bottom of the fork are for rebound, correct?
  2. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    check the alignment first:thumbsup:
  3. Big Timmy Husqvarna
    (South Eastern) AZ.
    Don't know what fork you have for sure. Rebound is usually on the top and compression adjustment is on the bottom.
  4. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    and make sure the pinch bolts on the lower tree are 12-15 lbs torque. tighter than that and they can bind the fork internally. with a new bike like that it would be wise to locate a service manual here that will give all the info you need for it...someone just posted up a link on here to a load of manual downloads..
    ray_ray and Big Timmy like this.
  5. justintendo klotz super techniplate junkie
  6. Jhunter Husqvarna
    Atlanta
    Ok, down on the compression clicker, is 'clock wise' the positive? Maybe counter clock wise is negative?
  7. Jhunter Husqvarna
    Atlanta
    This helps. I'll start with triple clamp torque and axel alignment. Then back out the compression.
    ADJUSTING THE FORK
    a) COMPRESSION (LOWER REGISTER)
    Standard calibration: -23 clicks.
    Remove plug (B) and turn register (A) clockwise to reach the position of fully clo- sed; then, turn back by the mentioned clicks. Turn the register clockwise to obtain a harder braking action.
    b) EXTENSION (upper register)
    Standard calibration: - 10 clicks
    To reset standard calibration turn register (C) clockwise to reach the position of fully closed; then, turn back by the mentioned clicks. To obtain a smoother braking action, turn the register anticlockwise. Reverse the operation in order to obtain a harder action.
    c) AIR VENT (to carry out after each competition, or monthly). Set the motorcycle on a central stand and release the fork fully and loosen the air vent valve (D). Once this operation is over, tighten the valve.
  8. Big Timmy Husqvarna
    (South Eastern) AZ.
    Yes,
    Turning the adjusters in clockwise is stiffer for compression. Clockwise rotation of the adjuster on top is stiffer on the rebound as well.
  9. WVdag Husqvarna
    Smithville, West Virginia
    2007 WR250 W/300 kit, 2013 CR125
    1987 Harley FXLR 10th year edition
    I would check/lower the oil level. Really made a big diffence in plushing mine out and getting full travel
  10. ray_ray Mini-Sponsor
    The Philippines
    Make sure all the alignments are correct as stated above and just open the clickers ... Its not gonna hurt anything to open the compression clickers up to within a couple clicks of wide-open or closed and see how the ride feels. You might learn something on suspensions ... And you gotta be a little careful with the clickers ...Some of that stuff is made pretty weak internally and can strip ...Meaning, do not force the turns...when it bottoms out, just stop turning :).
    Rebound is a different story, ESP if jumping the bike as you might not get lift off the jump face if the rebound is slower ... Whatever the default is, that's where I'd start.
    I've got the same bike and just lowered the oil in the forks to get a softer ride after the clickers would not give me what I was looking for.... Can't remember what my oil CC count is, but its pretty low off the default amount. I gotta go back out on the track with mine and might have to add oil back into mine.
  11. Jhunter Husqvarna
    Atlanta
    Great Info guys - Thanks. Suspension has always been my weakness. On my original '08, I had the suspension reworked by a local guru and it rides like butter! I bought this second WR250 for my college son to ride so I'm not investing a ton of money into it and it doesn't have to be perfect.
