fox air shocks upper chain guide
Discussion in 'Vintage/Left Kickers' started by flamepainter78, Feb 26, 2010.
  1. flamepainter78 Husqvarna
    norton,ohio
    Hi,I am looking for pictures or if anyone has made one of a fox air shocks upper chain guide for my 1978 390cr.I have copys of fox air shox owner's manual , but the pictures are very dark. any help? Thanks Doug.
  2. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    I will make one up for you if you paint flames on my 69 El Camino:thumbsup::cheers:
  3. fran...k. Husqvarna
    eastern ct
    I don't know if this was made using the instruction book or not.
  4. flamepainter78 Husqvarna
    norton,ohio
    Hi,How does it mount? By the shock and chain guide bolts. Thanks for the picture. Doug.
  5. IBHusky Husqvarna
    Imperial Beach
    Flame,
    Make it stout... This ones made from .250 6064 T4
    Photo's from a derailment while i was mid air on a table top during a moto.
    It got a little chewed but totaly saved the Air Shox.
  6. fran...k. Husqvarna
    eastern ct
    On the one I posted it looks like it is stainless steel but that probably doesn't matter much. The main piece bolts to the shock bolt but has about a half inch offset to the inside to clear the shock. That is two 90 degree bends about half an inch apart. The grinding you see is where it is welded to a smaller piece which goes down and attaches to the chain guide holding bolt. I must have knocked the chain roller guide forward in the process of getting it on the pail. You can see the smaller piece in front of the shock. That is an aftermarket swingarm so you might not have exactly the same placement of the chain guide.
    Fran
