frame color
Discussion in 'Vintage Restoration Projects' started by disonny, Nov 12, 2013.
  1. disonny Husqvarna
    upstate ny
    73 360 wr/rt, 75 wr250 78 cr250,
    83 wr250, 84 wr400
    What color silver is everyone using for their frame?
  2. 84scrambler Husqvarna
    mid Florida
    Spray paint or powder coat ? I went with spray paint (auto type) so when your boots scuff up both sides of the frame you can touch it up in 2 mins. Powder coat is not so easy how would you ever match that with out looking like you tried to match the paint and it did'nt... I think I went with gm silver from advanced auto it has metalic in it but it looks dam good when dries. Check out my build in vintage resto projects under My bad 79 wr.
  3. disonny Husqvarna
    upstate ny
    83 wr250, 84 wr400
    I was looking at your bike the other day. Looks nice. I'm doing the spray bomb job. It's a rider and like you said, it's easy to touch up.
    I see you went with the 40mm forks. What length shocks are you running? I have a 78 CR250 I'm doing. I bought a parts bike with 15 inch Ohlins. Can I run the 40mm forks? Here's a photo. Not the best pic but it was tight taking it. husky 001.jpg
  4. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
    I use duplicolor engine paint, aluminium on the the frame with the clear coat engine paint.
  5. 84scrambler Husqvarna
    mid Florida
    Yes 40's will work , you will have to change the triples too. My shocks are ohlin remotes they will be 16" when I am finished. After you strip the frame make sure you use a etching primer first then your regular primer it should help all to stick to the raw steel better. Good luck and have fun in the process and allow more time than you think..
  6. disonny Husqvarna
    upstate ny
    83 wr250, 84 wr400
    I have all winter to do it. With the time change it's dark at 5:15 now. So no outside playing til spring.
  7. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    ORIGINAL PAINT HUSQVARNA
    liquid
    CHRYSLER H84
    years 1988 /1993
    powder electric
    RAL 9006
    white aluminium
  8. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
  9. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
  10. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    before frame WR 1981
    after sandblasting
    and powder coatings
    200 C° !
    (powder AKZO NOBEL
    dupont de nemours )
    :thumbsup:
  11. GaryM Husqvarna
    Austin, Tx
    1981 430cr second 430 CR 500cr
    1981 490 Maico
    Note - I just used the Husky club H84 paint mixture. It is the best silver match I have seen yet.
    took a bit of time. I used base coat/ clear coat with enamel primer. Will post pics as soon as I can.
    Much prep work - I removed the powder myself. Note : the local blast shop kicked my parts out and did not complete blasting.
    Thats another story to tell !
    Powder coatings have failed in two different attempts by a couple locale shops for me. Do you know your powders ?
    Their are so many types of powder and how they are applied. One could not get a speck of any solvent, gas, etc ( melted ) , another the clear
    second coat needed for almost all silvers - check and cracked on the base silver.
    I choose to try painting - I will post pics soon. I will also post a powder coating chart to make sure you get the right kind of
    powder if you do powder coating.
    Please note if you use the Powder color noted above from Jim . Get a color chip first. I did. It is is very dark silver so I did not use it.
    it is not husky Silver.
  12. GaryM Husqvarna
    Austin, Tx
    1981 490 Maico
    Here for reference is a chart of how different make ups of powder coating performs.
    I did not know their is so may kinds of powder.
  13. jimspac Husqvarna
    Connecticut
    I am not sure how accurate a color chip is as I have never depended on them. I have never really seen an actual match between a color chip and what I get out of the spray gun.
  14. disonny Husqvarna
    upstate ny
    83 wr250, 84 wr400
    I tried the appliance epoxy paint but there was a lot of heavy over spray. After it dries there was a rough finish. Not sure if it was a bad batch of paint or what. I wound up using duplicolor silver engine paint with clear coat.
  15. jimspac Husqvarna
    Connecticut
    I used the appliance epoxy on my 1984 white frame. The key is to coat in several tack coats then go a wet coat that will flow out. I got into trouble by building coats too fast and ended up wet sanding a few coats off before I got the hang of it
