I have a 2011 TE 630 that I have swapped out the dirt wheels for warp 9 wheels. I want to add frame sliders. I see some for the SM 630 on ebay but I am not sure if they would fit the TE. I am mostly concerned with the front axle width. Does anyone know if they are the same?
I know that the SME axle sliders won't fit on the front of a TE without some small modification to a spacer. I tweaked one to fit for a member here on the lathe. The rear should fit no problem. Which set are you looking at? BTW, are you actually looking for frame sliders too, or just axle sliders? Axle sliders, handguards and a Hyde skidplate have saved all the expensive bits on my SMS a couple times.
http://www.ebay.com/itm/T-Rex-Husqv...Parts_Accessories&hash=item4600c5daa1&vxp=mtr I found some for the front but not any for the back. I have seen some generic sliders online as well. http://www.motostrano.com/SME-Axle-Slider-Bolt-Set-p/exset.htm With these you buy all thread and cut it to length. I could do that but would prefer a set that was designed for the bike.
Do we know if the 630 and the 610 swap? because if so...... http://www.supermotojunkie.com/show...e-Block-Sliders-by-R-Shafer-of-six-ninedesign
The rears are the same, but the fronts aren't quite identical. Also, if you buy the SM front sliders, they'll have to be tweaked to fit a TE axle.
What kind of modification? I bought my set of SME axle sliders when I had my SM but now I have a TE and the front isn't long enough to reach across. Is it possible to get a longer bolt? Or did you mill down the red spacer on the slider?
You can mill/turn down the spacer on the right side until the delrin piece is touching the fork end, then you will have enough threads and the sliders will be centered up left to right. If you've got someone with a lathe, they can turn it with a step to keep it in place, (or start a new spacer from scratch, it's about the same amount of work).
