250-500cc friction plates thickness
Discussion in '2 Stroke' started by nir, Feb 2, 2015.
  1. nir Husqvarna
    wr300 2010
    Having some problems with the clutch on my wr300,seems like the clutch is slippering. Anybody know the thickness? Chould it be the issue? Cheers
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Could be too tight on the cable, friction plate broken wrong oil spring broken or many other things, have you got a manual to check the thicknesses on?
    Hallscycles is a ch sponcer and have lots of manuals for husky free to download on pdf.
  3. nir Husqvarna
    wr300 2010
    It doesn't say the thickness on the manual. Everything looks fine inside. I just replace the oil and lube the cable with the same oils i used every time. I played with the cable as well.
  4. David Qualls Husqvarna
    Mt. Olive, IL
    2012 WR300
    1997 XR200, 1974 TS400
    I was just on Hall's web site and couldn't find a link to the bike manuals. Can you give me a hand?
  5. gots_a_sol Husqvarna
    Charles Town, WV
    WR177
    17 250RR
  6. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Friction plate thinkness for both my bikes is 3 mm minimum :cheers:
    2premo likes this.
