Front Brake Adjust
Discussion in 'Vintage/Left Kickers' started by gregg0323, Oct 4, 2015.
  1. gregg0323 Husqvarna
    430xc
    I put brand new front brake shoes and brand new cable on my 82 430xc. I had to extend the adjusters at both ends of cable to max in order to get them to bite hard enough to stop the bike. Would my drum be that worn where I have to max out both adjuster to make the brake work? Or, am I missing something in the adjustment?
  2. stormer254 Husqvarna
    England
    More than I dare let her know
    Yes!
    Shorten the cable inner.
  3. Jeff B Husqvarna
    1975wr 250
    yamaha ty 175,
    Some brands of brake shoes have a thinner liner than others. A reasonable option is have your old shoes relined. It is not as bad as you would think. Older Huskys such as my 75 wr 250 uses the small hub on the front . VERY hard to find any shoes. I switched to a 400 cross front wheel. The new shoes I find have a thinner liner on the shoe. I have a mill and a lathe in my shop. I machined a thicker brake cam. It works great. You want the lever on the hub to be in the best position to give the most leverage spreading the shoes. Also, relining gives you options on type of liner. You might find something better. Jeff
  4. grouty Auto Lover ...
    South West UK
    78 390WR, 78 390 AMX, 500 Humph
    works 73 CCM 520, another 73 CCM520
    I have found that new cables vary massively in length of inner and outer compared to O.E. I had issues with new Venhill cables. Some have been perfect, others not so. If you have used EBC shoes, they do seem to be thinner than O.E.
    The joy of keeping older bikes ... !
  5. stormer254 Husqvarna
    England
    Yes!
    Hence shorten the inner, as long as the lever on the brake plate is at the right angle, this is correct. I often make my own cables for this very reason!
  6. silverstreakNZ Husqvarna
    Christchurch nz
    82cr500,76gp360,90wr250,81 420AXC
    74 tm400 , 02 gasgas ec 300
    in nz we can get a green lining they refer to as "ambulance" lining . goes awesome in the back of the bsa .
