Bench Racer 117
I had a front brake line explode on me a while back. So I looked around and found a line off a KTM SX for $10. It is a little shorter than the stocker. After back bleading twice, it still is super spongy and takes a bit to bite. The braking power is pretty weak. It won't lock up if I try. I'll go around and test other bikes front brake and they have that initial braking power needed.
What could be going on? I pushed the caliper in, fed a bunch of fresh fluid up to the resv. with no bubbling. I don't like the way it feels. Could have to do with the brake line itself? The type of fluid used (Prestone Synthetic DOT4)? What about the brake components?
