Front Brakes
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Bill502, Oct 29, 2011.
  1. Bill502 Husqvarna
    Upstate NY
    2007 WR167 1978 CR250 1938 sw maus
    1970 Triumph T100C 1973 Honda TL125
    Is there a rebuild kit available for the front master cylinder? There looks to be a piston and some o-rings in the parts book but its listed as a Pin. When you pull the lever it grabs and then keeps going to the handle bar it won't hold pressure and I see no fluid leaking any where.
    Bill
  2. Auslander Husqvarna
    NY
    I had the same problem with my 125 and purchased the master cylinder rebuild kit and the caliper rebuild kit from partspitstop.com. I replaced the O-rings in the caliper first and that solved the problem, never rebuilt the master. There are two o-rings on each piston and you basically pump the lever until both pistons come out of the caliper at the same time, replace the o-rings, put the pistons back in the caliper then re-bleed the brake. In my case, the o-rings got worn by dirt/sand and started to let air into the system. I believe most KTM's EXCs use the same brembo brakes as yours with 28mm pistons. Here is a link to the caliper parts for a 2003 250exc, hope this helps:
    http://www.partspitstop.com/pages/o..._2003/Brake_Caliper_Front/1M03060010/03060055
  3. Bill502 Husqvarna
    Upstate NY
    Thanks, I'll bleed it out and see if the problem still is there, then order the parts.How's the 167 running I missed the gathering part 2.
  4. Auslander Husqvarna
    NY
    You could also try the trick of tying the brake lever all the way in and leave it overnight. This helps short term. I really like the 167, it's perfect for how I like to ride.
