Front CS Sprocket
Discussion in 'Motosportz' started by Fast1, Mar 8, 2009.
  1. Fast1 Husqvarna
    Minneapolis, MN
    I noticed you market front CS sprockets on your website and am wondeirng whay type they are?
    With all the recent discussion on the CS sprocket and output shaft fit I'm wondering if what you sell fits tighter than the stocky Husky product?
    Also are the brake pads you sell OEM or aftermarket?
    Lastly, do you have any photos of the 610 skid plate you sell on a bike?
    thanks,
  2. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    Fast1,
    I just purchased and installed an CS sprocket (13T) from Motorsportz and can attest that it definitely fits snugly on the splines. Zero radial and axial play once installed. Stock sprocket had developed some radial play and out of concern for that I replaced it. CS splines did not appear to have any discernible wear, although I didn't mic anything for numbers. Also, I didn't inspect the OEM sprocket when new to see how much play there was, if any. The new sprocket doesn't have lightening holes drilled through it between the splined opening and the teeth. It's completely solid. The snap ring just barely engaged in the groove, keeping axial play essentially zero. HTH
  3. Fast1 Husqvarna
    Minneapolis, MN
    who makes the CS?
    and thanks for the details on how it fit..
  4. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    I believe it was made by Sprocket Specialties? I'm 3000 miles away from my bike atm...sigh.
  5. fitness2go Husqvarna
    Seattle WA
    Greg...how's the retrieval going? What's your ETA?
  6. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    (off topic)
    Going slowly, found lots of problems inspecting these things. Big stuff. ETA hopefully NEXT week. Can't believe they expected us to fly across the continent with this crap in winter wx.
    (On topic now)
    Fast 1, is your CS sprocket getting play or just worn out from all those miles?
  7. Fast1 Husqvarna
    Minneapolis, MN
    I've got three that are all worn out.. 13, 14 and 15. I've purchased a new 13 but thought I might try a non-factory 15 for curiosity on the fit issue. The teeth on my old worn CS sprockets are curled waves...
    Knock Knock... is Mr. Motorsportz in the house??
  8. Motosportz CH Sponsor
    Brakes are after market, a couple brands. Same with CS sprockets. All the rears are Sprocket Specialties.
    Skid plate, simple, strong, effective. Change oil and filter without removing...
  9. Fast1 Husqvarna
    Minneapolis, MN
    thanks for the photos...
    which brand CS sprocket do you market that fits with the least movement on the ouput shaft?
    How do you specify that brand when ordering?
  10. rancher1 Husqvarna
    WA
    moose only makes 12 & 14 any other size will be sprocket specialists.
  11. Motosportz CH Sponsor
    What he said
  12. 04asphalt Husqvarna
    SW Michigan
    just got a 15 tooth, it is oem so I have an email in to kelly to confirm the fitting.
