Nope....the missing mounting points could be an issue for the start. Then a mold to produce something of the correct diameter. Angles are too sharp and intricate/ complex to heat-mold the item, so it has to be injection molded. Sold number of bikes too small to make this pay. Maybe adapt something from bikes like the
If you can find a guard similar to this? You can tap a thread into your axle (with minimal diameter & depth). Or like we do for the YZeds pass a bolt threw the axle, a quick measure shows approx 8 x 40mm for the TR (with the right size washer to catch the internal collar). Finish off with a dome cover or nut. Some trial and error required but its achievable. The second smaller bolt is the fork leg cover. Also quick release for when tracks dry out!!.
