front double leading brake compatability
Discussion in 'Vintage/Left Kickers' started by highdez1981430cr, May 11, 2011.
  1. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    Will a front double leading shoe brake and hub assy. fit on a mid 80`s 40 mm forks?
    Does anyone have a double leading brake and hub for sale?
  2. scoott Husqvarna
    Goldendale,WA
    17 Huskies from 1979 to 1987
    12 KTM's from 01 to 2010.
    The twin leading shoe brake and drum will fit all Husqvarna forks up through 1988. The older drums (pre 1983 ) are a shade too small for the twin-leading brake.
  3. Northern Husky Husqvarna
    Canada
    Yep, just went and had a look, twin leading shoe brake will fit on your mid 80s front disc(H2) forks. You cannot fit the disc to the earlier (H1) forks as they lack the mounting points.
    lve tried a double leading shoe brake over the stock brembo (its mounted on my avatar pic) not an improvement in any way shape or form. Currently working on a "gearco special" ......................forks and brakes from this millenium ;)
    Cheers
  4. street2dirt Husqvarna
    World's Most Famous Beach
    12 TXC310, WR300, 85 125WR, 82 175XC
    BMW G650X
    I'm looking to put a dbl leading on the '82, need drum brakes for my vintage class. I believe some had a different size axle but u can just swap out the bushing in the backing plate.......
  5. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    You need a 83-85 drum brake front wheel, for leading link brakes -as Husky changed the hub in 83.
    I've got a 81 wheel & a 84 brake set up & they don't fit.
  6. street2dirt Husqvarna
    BMW G650X
    Ah nuts, thanks ruwfo, I guess I'll be adding that to my list.......
