Front Fork Compression Adjusters Installed on '08 SM610
Discussion in '610/630' started by wallycycle, Feb 20, 2010.
  1. wallycycle Husqvarna
    Murrieta, Calif
    Just installed front fork compression adjusters (the ones that were supposed to be installed by the factory). What a difference. Now able to control fork dive on braking, less movement on acceleration and can balance front to rear suspension movement. Bike is now much more stable under aggressive riding. Highly recommend this mod. Inexpensive and easy to install !!
  2. Muddy Waters Husqvarna
    On the islands
    Ok, this might be silly of me to ask but I’m gonna anyway
    Where from, how much and how easy ? :excuseme:
    :thumbsup:
  3. WoodsChick Administrator
    Oakland, CA Miramonte, CA
    KTM, GasGas, Suzuki, Honda
    I know Les at LT-Racing was selling them. I think they were less than $100 if memory serves...
    Edit: Just checked his website...$94 per set. I guess my memory ain't so bad after all...
    WoodsChick
  4. wallycycle Husqvarna
    Murrieta, Calif
    WoodsChick is correct on the price and who sells them. Installation is easy. Need a vise to hold forks and the taps. Remove forks, invert and remove the existing tap. Leave fork inverted or else the oil will run out. Remove the valve/shim stack and large O-ring from the existing tap and install on the adjustable tap. The tricky thing to watch out for when removing the valve assembly is to hold everything together as a unit (valve/shims etc...) exactly as it's installed and transfer to the new tap. Otherwise you'll have 10+ little parts on your bench with no idea in what order it goes together.
  5. 04asphalt Husqvarna
    SW Michigan
    we need a "how to" with pictures :notworthy:
  6. rancher1 Husqvarna
    WA
    Motosportz also sells them, but they are complete adjusters, so you just remove your old ones and install your new ones, no messing around with the valve stacks.
  7. High-Side Husqvarna
    Where are they on their website?
  8. rancher1 Husqvarna
    WA
    I found them on page 3 of the motosportz forum here on cafe husky.
  9. High-Side Husqvarna
    Cool, found them! :thumbsup:
  10. wallycycle Husqvarna
    Murrieta, Calif
    Looked on the Motosportz forum page 3 referred to above by Rancher. The photo shows the adjusters without the valve/shim stack attached. I would check with Motosportz to confirm that the adjusters they sell come with the valve/shim stack if that is what you assume you are getting. If not, it's no big deal to take the valve/shim stack assembly off the stock tap. One bolt holds it on, you remove it and the assembly and transfer it to the adjustable tap and secure. VERY easy. Just grab it as one unit. Little cheaper at LT as well.
