Front number plate for 610? (rubber band clamp style)
Discussion in '610/630' started by Kyle Tarry, Feb 2, 2013.
  1. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    Anybody know of a front number plate that attaches using the same method as the stock 610 headlight (4 rubber bands)?
    I tried buying a KTM number plate of some sort but it's supposed to be bolted on so it doesn't have the holes for the rubber bands. The number plate for my WR has the new-style clip on the bottom, so that won't work on my 610 either.
    Just looking for an easy way to drop the headlight and put a race number on the bike for competition that doesn't require lights. I've been ziptying my number plate on but it doesn't fit well, looks dumb, and isn't very secure.
  2. Kyle Tarry Husqvarna
    Portland, OR
    C'mon guys, nothing? Somebody must have put a number plate on their 610, or have one of the older bikes with rubber band clamps...
  3. JonXX Administrator
    Bill's Motorcycles Plus
    360CR 360WR SM610 TC450 TXC250 TC250
    Hondas, Harleys, Yammys & a squid
    How about a TXC plate? I don't know anything, just throwing darts.
  4. Kyle Tarry Husqvarna
    Portland, OR
    The new TXCs (2012/2013) have the same style number plate as my WR, which mounts to the lower triple clamp with a little bracket and has a single bolted point off the upper triple (behind the gauge cluster on the bikes that have it).
    However, I wonder if one of the older TXCs might use the rubber bands...
  5. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    make an "I" bracket with perpendicular tabs and run any plate you wish. one tab fits where the top bolt and captured nut goes, another wider one at the bottom with holes and rubber grommets to capture the lower posts on the plate. basically expand on the factory TC type bracket. the top/bottom of the "I" made wide enough to reach the sliders with rubber coated or vinyl dipped bends in them to form fit to the leg and capture the rubber bands you rob from your headlamp or get from Acerbis or UFO etc. get creative, grind, paint, file, smooth, round off, should look sano when yer done and install in a jiff.
